Author Topic: Safe Mode  (Read 2462 times)
mrhoots
Safe Mode
« on: 16 August 2010, 16:23:13 »
I had to change my battery in my 1999 Elite. The radio was okay to use but the CD was in safe-mode. I put in the code the way i thought which was wrong but the radio has now locked in 'safe' Is there a length of time that I need to leave the radio before I put in the right code and do i need to have the ignition on? Please help as I don't like driving having to listen to my wife.  :'(
Re: Safe Mode
« Reply #1 on: 16 August 2010, 16:27:29 »
Which radio? Which CDC?
And also, which code haven't you entered, radio or cdc?
And, yes, ign needs to be on for duration of wait time, with no breaks.
mrhoots
Re: Safe Mode
« Reply #2 on: 16 August 2010, 16:35:53 »
Philips Bose, don't know product code. The cd is a Blaupunkt.
The radio was working okay but the CD player was in safe-mode. I didn't realise that both the radio & cd charger had different codes so I just read on the Safe Mode help on the blog and put in the radio code but this was the model code.  ;D
Re: Safe Mode
« Reply #3 on: 16 August 2010, 16:47:51 »
ccr800 and cdc2
Radio code
Ign on
Radio off
Press and hold AS
Turn radio on
Release AS when radio beeps
Enter code using 1234 buttons
Press and hold AS until beep
CD Code
Follow instructions above, but use the 0 button instead of AS.
mrhoots
Re: Safe Mode
« Reply #4 on: 16 August 2010, 19:32:12 »
Thanks for you help :y
mrhoots
Re: Safe Mode
« Reply #5 on: 16 August 2010, 19:38:32 »
Tried the 0 botton but does not seem to work, any advise?
mrhoots
Re: Safe Mode
« Reply #6 on: 19 August 2010, 17:02:53 »
I have found out today that you need to hold in the CD button and then turn on instead of the 0 button to access the CD code area.  :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Safe Mode
« Reply #7 on: 19 August 2010, 18:38:53 »
If you`d given us some usefull information to go on, such as the radio model number you have, we could have told you that a while ago !!
Radio & Decoding Technician
www.dndservices.co.uk
Re: Safe Mode
« Reply #8 on: 19 August 2010, 20:32:46 »
CCR800 doesn't have a CD button, it only has a 0 button that changes between radio, cassette and cdc?
Can't be a ccrt700, as the instructions above would have been incorrect. Me confuddled.
mrhoots
Re: Safe Mode
« Reply #9 on: 20 August 2010, 11:31:08 »
Still trying to understand the various parts of the Elite as I have not had one before and don't possess the manual. Thanks for your help. :y
« Last Edit: 20 August 2010, 11:31:47 by mrhoots »
