Author Topic: Aircon lights help  (Read 3793 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
Aircon lights help
« on: 23 August 2010, 10:00:58 »
Hi all my elite aircon lights for temp display don't work and can't see the temp!does changing the bulb in the back do it or is more complicated for those bulbs?I've taken them out on past omegas but wasn't sure about those bulbs,are they part of the LCD?the fan light buttons are all ok. :y
scream if you want to go faster!!!
Re: Aircon lights help
« Reply #1 on: 23 August 2010, 10:03:21 »
How's this? .......  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1162120610
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #2 on: 23 August 2010, 11:24:57 »
As Andy has already said above, plus you can buy the bulbs on their own, you do not need the holder (just pull bulb out). It works out cheaper like that as you will need to replace all temp/fan bulbs as per guide. For some reason, if you replace one or two the others go shortly after.  :y :y
« Last Edit: 23 August 2010, 14:08:09 by Alan-Hearn »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 23 August 2010, 22:30:58 »
Unfortunately, if all the bulbs failed at the same time, it's more than likely that the PCB is at fault.  I've had a Climate Panel which was faulty, and had to 'bodge' it to make the bulbs illuminate.  Not a terrifically difficult job to do, but easier to fit another panel.  :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #4 on: 23 August 2010, 22:42:06 »
...plus you can buy the bulbs on their own, you do not need the holder (just pull bulb out).
Are you sure? I seem to remember replacing the bulbs in my old Vectra's climate panel and they looked similar to the type you describe but they were soldered into position, rather than just pushed in...
YZ250
« Reply #5 on: 24 August 2010, 01:47:21 »
100% sure. I'm looking at one right now. It is even a Halfords part and can be found with their bulbs with the packet number 286.
The bulb glass goes flat on the end and has a wire bent up each side. Vauxhall were going to sell me the whole part until a technician walked past and asked me why I was buying the complete part when all I needed was the bulb. :y :y
I can attach a photo if required. :y
« Reply #6 on: 24 August 2010, 08:09:31 »
not all these types of lamp come seperate from its holder.  ;)
mr ICE man
  • dolgellau wales
« Reply #7 on: 24 August 2010, 09:39:58 »
I ask this question because I have changed the bulbs in past omegas that had the same fault but they still didn't work,am I missing changing some bulbs??which ones are for the LCD displays?
YZ250
« Reply #8 on: 24 August 2010, 10:25:22 »
The LCD displays are illuminated by the 1.2w push/twist bulbs that sit behind the display 'pod'.  :y
mr ICE man
  • dolgellau wales
« Reply #9 on: 24 August 2010, 11:04:52 »
Thanks guys!
