Author Topic: fuse blown :(  (Read 4178 times)
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
fuse blown :(
« on: 18 August 2010, 13:15:39 »
the fuse for the interior lights in blown,
guess that also also affect the boot light and the driver seat ??
cuz all of that dont work now,
anyone know which fuse to change ??
and how many to change ??
( you can see which car I have from the left )
Re: fuse blown :(
« Reply #1 on: 18 August 2010, 13:18:14 »
Fazeel
  • Bahrain
Re: fuse blown :(
« Reply #2 on: 18 August 2010, 13:21:14 »
Fuse list here .... Page 186/7
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
guess that's why the coutesy light doesnt work either
:P ;D ;D
Fazeel
  • Bahrain
Re: fuse blown :(
« Reply #3 on: 18 August 2010, 13:29:58 »
ok and another thing,
Am I supposed to check the fuses while engine running or not ??
and are all fuses supposed to work ?
cause last time I checked them, there were many of them not working so I thought maybe it's meant to be like that and I shouldnt be meddling with them,
I thought maybe they work according to when being used or something,
so if anybody could clarify me there things it would be very helpful
shane1000
  • derby
  • studied nothing for 35yrs so now an expert on it
Re: fuse blown :(
« Reply #4 on: 19 August 2010, 19:35:07 »
definately do not check fuses with engine on or with the keys in at all ... you will blow them every time.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: fuse blown :(
« Reply #5 on: 20 August 2010, 19:00:07 »
I always check fuses with the ignition on? Isn't that what the two little holes on top of the fuses are for? So you can touch an electrical tester on them and check for voltage?
Fazeel
  • Bahrain
Re: fuse blown :(
« Reply #6 on: 20 August 2010, 21:36:48 »
Yeah, dats exactly what I do
shane1000
  • derby
Re: fuse blown :(
« Reply #7 on: 24 August 2010, 19:04:00 »
would it not be better to take the fuse out completely to check so that when you replace it you push it all the way back in ? thus ensuring a snug fit and checking for loose fitting at the same time ?
peterm
Re: fuse blown :(
« Reply #8 on: 24 August 2010, 20:31:55 »
the hole in top of fuse is so you can see if blow and that depend on if it has blow the right way as some only go at one end and may not notice
you should not have inition on ever as can cause other problems as well best pull fuses look at them and see if ther is a break in them and replace as neede
and as for ones working or not system will only put power on them when need  like likte when light are on  and same for any thing like that
Brikhead
  • West-Mids.
Re: fuse blown :(
« Reply #9 on: 24 August 2010, 22:30:51 »
Yes, that is the best way to do it but it can be very time consuming, pulling out 40 odd fuses to give each one a visual inspection.
I started to learn what little I know about car electrics by fitting stereos at the age of 12, I used to quickly touch the wires to earth to identify the live...
zvi
  • IL
Re: fuse blown :(
« Reply #10 on: 24 August 2010, 23:51:45 »
Shorten to earth is the wrong way it's better to check with a meter or lamp. Don't need to get every one out there's a user manual details the use of a fuse. so just check the relevent one
Re: fuse blown :(
« Reply #11 on: 25 August 2010, 00:03:29 »
Hence well practiced at checking fuses.  ;)
Why not have a look at the wiring diagrams. They will tell you which fuse you need to check.
tidla
  • solihull
Re: fuse blown :(
« Reply #12 on: 25 August 2010, 00:25:10 »
 ;D
im sure theres been progress to a curcuit tester pen when the pocket money come in.
Brikhead
  • West-Mids.
Re: fuse blown :(
« Reply #13 on: 25 August 2010, 11:56:26 »
;D
I have a multimeter now, I nearly understand how to work it.
