Author Topic: master light switch illumination  (Read 5167 times)
lightfj
  • Liverpool
« on: 24 August 2010, 09:37:02 »
Does anyone have a photo of the back of the master light switch please?
The dashboard illumination light is hanging in free space and I cant feel the hole with my finger. Surely I won't have to remove the whole switch assembly to plug the little blighter back in.
Thanks in advance
Jeff
Welung666
Re: master light switch illumination
« Reply #1 on: 24 August 2010, 10:38:41 »
Open the drivers door and pop the end plate off the dash. You should be able to reach it from there :y
« Last Edit: 24 August 2010, 10:39:01 by Welung666 »
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #2 on: 24 August 2010, 10:41:27 »
I have a light switch off the car if you still need a picture... :y
lightfj
  • Liverpool
« Reply #3 on: 25 August 2010, 15:37:53 »
I really would appreciate a pic if you can please brikhead.
I cant see or feel where the illimination light fits in.
Apic of the rear of the switch would be superb.
Thanks in aadvance
Brikhead
  • West-Mids.
« Reply #4 on: 25 August 2010, 23:12:00 »
I'll sort a picture Mate, no problem... From memory the bulb is located fairly centrally, but is recessed in, so I'd imagine it would be awkward to see. I'll find out the bulb type and wattage as-well so you can have one to hand when you do yours...
Brikhead
  • West-Mids.
« Reply #5 on: 25 August 2010, 23:13:40 »
Hopefully my 1999 prefacelift will be the same as your facelift?
lightfj
  • Liverpool
« Reply #6 on: 26 August 2010, 11:21:49 »
Bulb exists in a not quite square holder which just plugs into a hole. A small groove on the plastic holder makes it only fit one way.
Thanks
lightfj
Brikhead
  • West-Mids.
« Reply #7 on: 26 August 2010, 12:20:02 »
Here you go...
The bulb is 0.5w and you will need the type that come fixed into the holder, the bulb does not just pull out from the holder.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #8 on: 26 August 2010, 14:05:02 »
Thanks
lightfj
Is there some confusion here.  :-/ Surely this is the vent illumination bulb and can be reached as already described by Welung666.
It's holder will be on the end of a wire loom and just pushes in the end of the dash beside the vent when you have removed the end plate.
Fair play to Brikhead for the photo though as it is what the OP asked for. :y :y
« Last Edit: 26 August 2010, 16:32:23 by Alan-Hearn »
Brikhead
  • West-Mids.
« Reply #9 on: 26 August 2010, 19:32:12 »
Thanks in advance
Jeff
 ;D Oh, You just need to plug in the bulb for the vent trim?
I did wonder how it could be swinging about!
Brikhead
  • West-Mids.
« Reply #10 on: 26 August 2010, 19:34:34 »
You want another picture of the rear of the vent assembly! Thats removed from the car, also!
lightfj
  • Liverpool
« Reply #11 on: 27 August 2010, 10:39:21 »
Seems I've got it wrong!!!!!
Sincere apologies for time wasting but yes please another pic will be excellent.
Many thanks Brikhead fot your indulgence.
Kindest regards
Brikhead
  • West-Mids.
« Reply #12 on: 27 August 2010, 15:38:48 »
No problem.
I'm guessing something must be broken on yours... the bulb holders usually just push back in.
I'll sort a picture for you in a while.
lightfj
  • Liverpool
« Reply #13 on: 27 August 2010, 15:48:39 »
yes that's right but I can't figure out where it pushes in to.
Welung666
« Reply #14 on: 27 August 2010, 16:00:25 »
With the side panel off the dash, move the vent open/shut wheel and you'll see the wedge move. With the vent set to fully open the top of the wedge should be horizontal. Feel just inside the lip of the dash level with the top edge of the vent wedge and you'll feel the hole. Use the top edge of the vent wedge as a guide and slip the bulb back in :y
