Author Topic: none of the instruments and control indicator work  (Read 3107 times)
viajero
« on: 27 August 2010, 16:01:21 »
Hi everybody, I got an Omega B 3,2 two weeks ago and it seemed to be doing fine. This morning however none of the instruments (tachometer, speedometer, temperature gauge, fuel gauge) and the control indicator lights were working, only a battery symbol lighting up strongly. Under the car, I found a puddle of a pinkish colour. What could this mean? Thanks for your comments!
Welung666
Re: none of the instruments and control indicator work
« Reply #1 on: 27 August 2010, 16:06:12 »
The pink liquid could very well be coolant. Where under the car was it?
Has the dash been disturbed for any reason recently?
viajero
« Reply #2 on: 27 August 2010, 16:18:31 »
Thanks, that's quick! I already suspected it's coolant, but it feels a bit greasy. The puddle is situated under the engine, near the radiator. Everything worked fine until this morning, don't know if anyone has touched the dash lately, not in the two weeks that I have had it!
  • Auckland
    • Mazda MPV
« Reply #3 on: 27 August 2010, 20:58:59 »
Is it automatic transmission fluid?
I can't imagine how this might effect the electrics though  :-/
« Reply #4 on: 27 August 2010, 20:59:46 »
Check fuses 12 & 15 ;) ;)
These fuses covers many things, incuding the dash and indicator control.  It also covers the cooling fan, so there may just be a connection there with the fluid loss (???) ;) ;)
« Last Edit: 27 August 2010, 21:05:42 by Lizzie_Zoom »
viajero
« Reply #5 on: 28 August 2010, 16:18:42 »
As a matter of fact it wàs fuse 15. Thanks a 1.000.000! :
« Reply #6 on: 28 August 2010, 16:21:04 »
 :y :y :y :y :y  Glad you found the answer! :D :D ;)
How about the fluid loss though? :-/
viajero
« Reply #7 on: 28 August 2010, 18:07:37 »
it must have been coolant, because the pressure tankwas completetely empty, I added about half a gallon....
« Reply #8 on: 28 August 2010, 18:29:57 »
Oh dear! :o :o
You must have a leak to lose that much.  Feel around the HBV at the back of the engine ;) ;)
viajero
« Reply #9 on: 28 August 2010, 20:26:24 »
May I ask what is an HBV?
« Reply #10 on: 28 August 2010, 20:30:50 »
Yes, look through this guide and you will see the HBV (Heater Bypass Valve), with instructions how to replace if necessary:
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
« Last Edit: 28 August 2010, 20:31:51 by Lizzie_Zoom »
viajero
« Reply #11 on: 30 August 2010, 19:24:54 »
Thanks very much again! But no more problems after I changed fuse 15, other than fuse 15 blew again this morning....
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #12 on: 30 August 2010, 20:41:17 »
I'm sorry to say, I had this problem (and since have found others who have had the same problem).
The circuit controls a lot of items in the car, so locating a fault is very time consuming.  I gave up in the end and ran a new fused live feed to everything it controls (Drivers Memory Seat, All Interior Lights, Dash Clocks, MID, Stereo, Climate Panel, etc etc).
About a fortnight after, my cambelt snapped  ;D
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #13 on: 31 August 2010, 12:24:01 »
Have a look at these threads about my problem with fuse 15..
Does the engine stop when it blows ?
http://www.omegaowners.com/forum/YaBB.pl?num=1269801448/8#8
http://www.omegaowners.com/forum/YaBB.pl?num=1269201094/12#12
http://www.omegaowners.com/forum/YaBB.pl?num=1256850472/14#14
Mine was eventually traced to the drivers heated seat wiring rubbing on the seat frame. You can isolate that by disconnecting the heated seat feed down on the right hand side by the seat controls. But be careful the air bag and seat belt tensioners go through here as well.
viajero
« Reply #14 on: 01 September 2010, 19:43:33 »
No, the engine doesn't stop. Last time the fuse blew I had just turned on the radio, that was three days ago. I haven't turned the radio on since and everything has been fine, so far... Thanks all of you for your comments and hope the cambelt has been fixed!
By the way, the car and I, we are in Kuwait, where it has been over 50 degrees centigrade of late...
