Author Topic: cruise control  (Read 4461 times)
motmannn
cruise control
« on: 05 September 2010, 11:04:14 »
can someone remind me/point me in the right direction/ the elite estate had cruise control the v6 tourer does not, if i remember you can fit the wiper contol/multifunction and do something else to retro fit cruise ??
MickAP
  • South Derbyshire
Re: cruise control
« Reply #1 on: 05 September 2010, 11:12:59 »
Have a look here, under retro fitting features (electrical)
http://www.omegaowners.com/forum/YaBB.pl?num=1259003779
Does this help.
I've only fitted cruise on a TD facelift, and that was a doddle, plug and play. Different on other models.
Mick
Re: cruise control
« Reply #2 on: 05 September 2010, 11:13:37 »
would help if you told us exactly which V6 engine  ;)
But given you said Tourer that suggests a 2.5 V6, which will need stalk, actuator, plenum mount and all other bits and bobs for cable driven cruise system.
Its stalk only for DBW engines (2.2,2.5TD,2.6,3.2)
motmannn
Re: cruise control
« Reply #3 on: 05 September 2010, 11:16:44 »
ah ha! i remember now! facelift plug and play older one needs all the gubbins! thanks guys!! :y
Re: cruise control
« Reply #4 on: 05 September 2010, 13:42:51 »
Facelift or not has nothing to do it with it, its what engine is fitted ;)  :y
MickAP
  • South Derbyshire
Re: cruise control
« Reply #5 on: 05 September 2010, 17:30:28 »
All I know is TD facelift DBW is plug & play.
Facelift DBW petrol 2.2  is also the same but needs Tech2 to enable.
As regards the rest well, some need all the gubbins like switches on the pedals etc, but I'm no expert on that ::)
If your going for a cruise stalk it's recommended to get new, or one that's not seen much use :y
Mick ;)
Mick
