Pages: 1 [2] 3  All   Go Down
Author Topic: can a ncdc 2013 be de bosed  (Read 11539 times)
charlie
  • sunderland
Re: can a ncdc 2013 be de bosed
« Reply #15 on: 22 August 2010, 22:55:38 »
will do, because charlie plus eletrics =fire ;D ;D ;D
« Reply #16 on: 23 August 2010, 18:59:04 »
Correct me if I'm wrong, but if you're going to reconfig. the head unit to be non-bose and install in a car that doesn't have Bose the speaker outputs will just connect to the existing loom?
Might need some tweaking of the display wiring, as said, of course....
« Reply #17 on: 23 August 2010, 19:11:49 »
yup
    • 530D M Sport, 330i Coupe
« Reply #18 on: 23 August 2010, 21:06:45 »
yup
Yep, was just trying to point out that if the OP did want to look into Bose'ing the car then there is a bit more to do on a facelift!  :y
charlie
  • sunderland
« Reply #19 on: 23 August 2010, 21:10:30 »
I was going to put it into a non bose car.But i have had another look at the bose wiring harness and believe i could retrofit that aswell,as i've got the speakers amp wiring etc.Now thinking about it,its becoming more of a  challenge.  :y
charlie
  • sunderland
« Reply #20 on: 23 August 2010, 21:16:14 »
yup
I understand that theres no plug and play on the facelifts for the bose system.i have got some of the wiring from the radio to kick panel and a few spare,36 outlet connectors to make, hopefully a working loom :y
« Reply #21 on: 24 August 2010, 22:11:00 »
Ideally you need a 36 ISO male and female fully wired (A trafficmaster sub-loom is the best solution) then take your tails for the screen and Bose link from the Male end (which the cars loom will now plug into).
This can then be tucked on the r/h side of the console (the only place where there is space.
I found the easiest way to install the cabling to the kick panel connector was to make up your loom from the trafficmaster sub loom, install it and route the cabling out along the original cabling route and under the steering column / around the pedal box (taking particular care to make sure nothing snags) then 'graft' the kick panel connector on afterwards. There isn't an option to make the complete loom up first then install because there just isn't the room to feed any of the connectors through the route required.
charlie
  • sunderland
« Reply #22 on: 25 August 2010, 10:58:14 »
some quick Questions.Q1 after the speakers have been though the amp can i join back up with existing speaker wires/Or do you,extend the thicker wires to each door.Q2 On the car harness the four sets of speaker wires branch off to the earth( 0 volts)for the radio.can i put these to an earth ie the body? hope with makes sense. cheers charlie :y
« Reply #23 on: 25 August 2010, 18:51:32 »
Q1 Yep, the speaker outputs from the radio go to the bose amp and the return outputs fromthe amp go to the speakers.
Q2 On a OEM Bose install the speaker outputs from the head unit are caried in two core shielded cable, the shield goes to 0V.
charlie
  • sunderland
« Reply #24 on: 25 August 2010, 19:00:06 »
ON q1 after the speaker wires have been routed to the amp, can the out wires be routed back to the main harness?.also what picture or abbr on the radio is the remote wire? cheers charlie
« Reply #25 on: 25 August 2010, 19:17:33 »
Yes, On my loom I used a trafficmaster loom, cut the speaker outputs, soldered flyleads to both ends, routed them down to the kick panel then soldered them to the kick panel connector I obtained from a breaker.
charlie
  • sunderland
« Reply #26 on: 04 September 2010, 17:14:12 »
Well this as started today,few hiccups 1 theres no holes for rear shelf speakers >:(
« Reply #27 on: 05 September 2010, 23:27:19 »
Some of them have perforations to allow you to cut the holes out.
« Reply #28 on: 06 September 2010, 07:23:41 »
I think only up to 1998
charlie
  • sunderland
« Reply #29 on: 06 September 2010, 11:52:59 »
back to basics
Pages: 1 [2] 3  All   Go Up
Page created in 0.022 seconds with 20 queries.
