Author Topic: Door locks / air bags / seat belt tensioners  (Read 2454 times)
« on: 09 September 2010, 22:52:57 »
Looking at the handbook and given some symptoms I assume these are all interconnected... ::)
My door locks do not work as they should, they work on the fob but if you manually push the button down you CAN not pull it up again. You have to use the fob, even from inside the car. You CAN push the button down with the door open, the manual suggests you can not as a precaution against locking your keys in the car...
The manual also says that in the event of an accident the doors will unlock, hence why I feel there is a connection..
The air bag light is on constantly, in every other way everything works as it should....
Philrich tried to reset the light but could not manage (Monkeys) :D :D
I have checked the various connections, found some disturbed by the passenger seat but all well now...Any thoughts on this? or is it into the dealers / auto electrics for a diagnosis.... :)
charlie
  • sunderland
Re: Door locks / air bags / seat belt tensioners
« Reply #1 on: 09 September 2010, 23:00:50 »
I would have a look in drivers door as theres is sensors in there for the airbag system ,plus you can have a look at the locking system, :yAs for the airbag light,the system not happy about something
charlie
  • sunderland
« Reply #2 on: 09 September 2010, 23:03:26 »
When the door trims off you can check the plastic membrane to see if any bodys been in there already
« Reply #3 on: 09 September 2010, 23:50:39 »
Once the airbag light is on it can only be reset using a proper tech2 I believe.
You found disturbed connections which may well have been the cause of the light coming on ... so a tech2 to turn it off .. :(
« Reply #4 on: 10 September 2010, 00:14:07 »
Guess it is auto electrics or main dealer then, nearest tech 2 would be H21
« Reply #5 on: 11 September 2010, 01:51:13 »
Come on peeps need some advice here...... :)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #6 on: 12 September 2010, 14:34:47 »
What is the airbag ECU complaining about?
Have a look at the live data to see what it's unhappy with.
Jimbob had an issue on his last car that he narrowed down by comparing the resistances shown on the live data screen.
As ever be careful when messing with airbags (or at least video it for our amusemment.) ;D ;D
TuBy's new whipping boy.
« Reply #7 on: 12 September 2010, 20:57:23 »
Yer pays Peanuts, yer get..................... ::) ;)
« Reply #8 on: 13 September 2010, 00:00:05 »
The cheek of it, bloomin Monkeys.... :P :P :-* :-*
« Reply #9 on: 14 September 2010, 00:17:50 »
Engine off, pushed door lock down, could not pull up driver or pasenger, but could unlock both back doors..come on chaps, someone must have had the same problem, or know the answer, this is OOF after all.... :) :)
