Author Topic: re auto wipers  (Read 4106 times)
rbramm
  • lanarkshire scotland
  • 2000 w 2.5 v6 elite.
re auto wipers
« on: 17 September 2010, 19:55:02 »
hi all. i have seen that a lot of people say the facelift elite version should have rain sensing wipers.
i have a 2.5 facelift elite but it does not have this option. everything else is there including working rear blind but no rain sensing wipers.
would anyone have an idea why this is. ie only fitted to 2.6 3.2 etc
or should it be there and someone has removed to repair etc.
thanks in advance. :) 8-)
Re: re auto wipers
« Reply #1 on: 17 September 2010, 20:02:47 »
Generally only on late cars.
If it has it, the rear view mirror has the larger base, which houses the sensor, and the windscreen is different
rbramm
Re: re auto wipers
« Reply #2 on: 17 September 2010, 20:14:03 »
probably just cause mine is early facelift 2000 w then. stalk only has option for int. std and fast. thanks for the reply.   :y
joshwyatt
  • Oxford
Re: re auto wipers
« Reply #3 on: 17 September 2010, 20:20:56 »
As TB says, it's only found on later vehicles. I have seen some '02' plates with and without, but typically all '52' plates and later do have rain sensing wipers.
This is what the rain sense looks like...
Re: re auto wipers
« Reply #4 on: 17 September 2010, 20:30:15 »
This is what the rain sense looks like... ....
not exactly subtle!  ::)
Re: re auto wipers
« Reply #5 on: 17 September 2010, 21:33:15 »
Actually, its not too bad - over emphasised for that pic
    • 530D M Sport, 330i Coupe
Re: re auto wipers
« Reply #6 on: 17 September 2010, 21:50:58 »
That reminds me.... Must make sure I mention that the DTi has rain-sensing wipers when I get around to getting a new screen in it.
rbramm
Re: re auto wipers
« Reply #7 on: 18 September 2010, 19:02:33 »
many thanks for all the replies peeps. was just wondering if it should be there and someone had removed it.
looks like it wasnt fitted.
cool one less thing to go wrong lol.  :y
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: re auto wipers
« Reply #8 on: 26 September 2010, 01:49:50 »
Is this something that is easy to retrofit to a mig without?
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
rbramm
Re: re auto wipers
« Reply #9 on: 26 September 2010, 10:32:52 »
sounds like a lot of messing with wiring. different wiper stalk. different mirror and base and different windscreen.
could be costly and a lot of work.
think i will stick with moving the stalk with my hand lol.  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: re auto wipers
« Reply #10 on: 29 September 2010, 08:54:59 »
my early f/lift elite doesn't have it either :'(
other rides
Lampynoiseboy
  • SE Essex
Re: re auto wipers
« Reply #11 on: 29 September 2010, 19:51:58 »
Wiring- I can do
Stalk- ditto
Mirror- ditto
Windscreen- Cracked already, drink for autoglass man when he gets here  ;)
Re: re auto wipers
« Reply #12 on: 30 September 2010, 11:17:38 »
Wiring- I can do
Stalk- ditto
Mirror- ditto
The wiring is already there in my car. I believe the stalk is the same - unless you have the variable intermittent wipe? (In which case, is it worth bothering?).
Think you just need to remove the intermittent wipe timer module, install another box of tricks of some sort - probably just a relay - in the engine bay fuse box and fit the mirror housing with sensor.
Then take one of LBC's finest.. Oops! :o And a call to the windscreen outfit of your choice. ;)
twiglet
  • Norwich, Norfolk
Re: re auto wipers
« Reply #13 on: 30 September 2010, 12:57:00 »
While we are on the subject of windscreens....
My 53 plate elite has auto wipers, but a standard green tint screen with a darker sunshade strip along the top.  I have seen some migs with the solar screen (looks purple from a distance), and am considering changing for this as and when my screen needs replacing.
Does anyone have and comments (good or bad) on these screens, and know whether they still have the sun shad strip and auto wipers built in?
Also, my car is a black estate, and I'm undecided as to whether the purple look of the screen would look right or not, and thoughts?
Cheers  :y
joshwyatt
  • Oxford
Re: re auto wipers
« Reply #14 on: 30 September 2010, 13:13:38 »
The photo I attached above is from an Elite estate I currently have, it has the solar reflect screen. Here's a link to a few pictures, you can see it does look quite purple...
http://www.omegaowners.com/forum/YaBB.pl?num=1285347829
The solar screen does still have auto wipers and sunshade strip. The only negative I've heard is that it can make it harder for portable sat navs, i.e tomtom's etc to get a good signal. I've never experienced this as I've never used a portable sat nav in the estate.
Page created in 0.028 seconds with 20 queries.
