Author Topic: Washers  (Read 2170 times)
des.allen
  • Preston lancs
  • 2000 2.5 v6 elite nearly LPG
Washers
« on: 17 October 2010, 13:21:24 »
Hi All, Can anyone please tell me where and how to get to the connections for the washer bottle. My fuse keeps blowing and i have checked all the wires around the wiper motor etc and noticed the fuse only blows if I use the washers TIA
Welung666
Re: Washers
« Reply #1 on: 17 October 2010, 13:23:16 »
Pre-facelift/mini-facelift - open the bonnet, remove the grill and the pump is just below where the grill was.
Facelift - just open the bonnet.
If it blows when you use then it could be the motor seized or jammed up with gunge :y
« Last Edit: 17 October 2010, 13:24:09 by Welung666 »
des.allen
  • Preston lancs
Re: Washers
« Reply #2 on: 17 October 2010, 13:29:45 »
Cheers for quick reply,  Problem is it doesnt always do it! I have removed wet foam from under skuttle and taped up the wires going to the wiper motor and this is the next port of call, I hate wireing so just trying to make sure there is nothing obvious.
des.allen
  • Preston lancs
Re: Washers
« Reply #3 on: 18 October 2010, 18:45:04 »
Bloody wipers decided to pack up again on motorway >:( anyone had simular problems? the fuse just randomly blows and sometimes goes straight away or can be ok for ages then go at the worst possible moment.
Kneepad
  • West Scotland
Re: Washers
« Reply #4 on: 18 October 2010, 20:43:25 »
Try disconnecting the washer pump and drive it for a while, you need to determine if the fault is with the pump or the wipers.
des.allen
  • Preston lancs
Re: Washers
« Reply #5 on: 19 October 2010, 10:53:12 »
what a good idea  :y why didnt I think of that! It seems to blow when you either pull for washers or just give it a nudge to go onto a quick wipe if you know what i mean? but then again it can just stop mid sweep which it decided to do last night >:(
