Author Topic: beeping noise  (Read 6242 times)
marke
  • manchester
beeping noise
« on: 23 October 2010, 19:27:29 »
can someone please tell me what a power sounder is as i keepgetting strange beeps ? :y
Re: beeping noise
« Reply #1 on: 23 October 2010, 19:51:52 »
Battery backed alarm siren, part of the Anti Theft system, designed to go off when some scote disconnects battery whilst trying to disable alarm
Re: beeping noise
« Reply #2 on: 23 October 2010, 19:52:08 »
it's a battery backed up siren & lives in the driver's side scuttle area.  :y Beeps can be an indication that it's fubar'd  :y
marke
  • manchester
Re: beeping noise
« Reply #3 on: 23 October 2010, 19:54:44 »
hi only get it now and then does it need my atention :y
Re: beeping noise
« Reply #4 on: 23 October 2010, 19:59:56 »
.... and then does it need my atention :y
Just unplug it.  :)
davethediver
  • Blackburn, Lancs.
Re: beeping noise
« Reply #5 on: 23 October 2010, 20:04:37 »
Just unplug it.  :)
Before it torches your car :o :o
P.A. Caron de Beaumarchais
marke
  • manchester
Re: beeping noise
« Reply #6 on: 23 October 2010, 20:23:25 »
torches my car how do i unplug please :o
Re: beeping noise
« Reply #7 on: 23 October 2010, 20:26:08 »
Locate power sounder as described, hold the plug & pull  ::) :y
marke
  • manchester
Re: beeping noise
« Reply #8 on: 23 October 2010, 20:32:42 »
ha ha just read were it is located you sure i just pull :y
Re: beeping noise
« Reply #9 on: 23 October 2010, 20:48:03 »
more or less, I'm sure there'll be a clip you've to unlatch first .....  ;) ;) ;)
If you can't find it in the next fortnight & it's still not been in flames ....  ::) someone at Chester services will sort it for you  :y :y :y
Kneepad
  • West Scotland
Re: beeping noise
« Reply #10 on: 23 October 2010, 21:19:07 »
Don't be alarmed when you unplug it, this will usually activate it, but it will stop after a while  ;D
You could also try replacing the batteries inside it, then plug it back in. :y
skyblue
  • Bracknell
Re: beeping noise
« Reply #11 on: 24 October 2010, 23:17:51 »
[/b]
Is this a main dealer part only as I think mine is starting to go. Im getting this beep every now and then so I suspect that this is the cause. Im right in thinking once its disconnected the alarm system wont work if the car battery is disconnected
skyblue
  • Bracknell
Re: beeping noise
« Reply #12 on: 24 October 2010, 23:23:51 »
Just looked at another topic on this and have had my question answered  already.... must make a mental note for myself..... look at other topics before asking the same question :-[ :-[
Re: beeping noise
« Reply #13 on: 24 October 2010, 23:29:17 »
Don't worry about it, there's tons of info here to wade through. The complete power sounder is available from the dealers - £60ish IIRC - but changing the batteries requires a hacksaw to cut it open. I'm sure there's a how2do somewhere.  ;) ;) ;)
skyblue
  • Bracknell
Re: beeping noise
« Reply #14 on: 24 October 2010, 23:36:36 »
Thanks Andy. This has only started since I disconnected the battery a few wks back so It looks like im gonna be 60 quid shorter this month  :(
Dont know if Vauxhall fit these to all there cars ( daughter has a corsa and her  alarm never seems to go off  even if she leaves the window open.... so im thinking has this been removed  ???)
