Author Topic: beeping noise  (Read 4818 times)
marke
  • manchester
beeping noise
« on: 23 October 2010, 19:27:29 »
can someone please tell me what a power sounder is as i keepgetting strange beeps ? :y
Re: beeping noise
« Reply #1 on: 23 October 2010, 19:51:52 »
Battery backed alarm siren, part of the Anti Theft system, designed to go off when some scote disconnects battery whilst trying to disable alarm
Re: beeping noise
« Reply #2 on: 23 October 2010, 19:52:08 »
it's a battery backed up siren & lives in the driver's side scuttle area.  :y Beeps can be an indication that it's fubar'd  :y
marke
  • manchester
Re: beeping noise
« Reply #3 on: 23 October 2010, 19:54:44 »
hi only get it now and then does it need my atention :y
Re: beeping noise
« Reply #4 on: 23 October 2010, 19:59:56 »
.... and then does it need my atention :y
Just unplug it.  :)
davethediver
  • Blackburn, Lancs.
Re: beeping noise
« Reply #5 on: 23 October 2010, 20:04:37 »
Just unplug it.  :)
Before it torches your car :o :o
“It is not necessary to understand things in order to argue about them.”
P.A. Caron de Beaumarchais
marke
  • manchester
Re: beeping noise
« Reply #6 on: 23 October 2010, 20:23:25 »
torches my car how do i unplug please :o
Re: beeping noise
« Reply #7 on: 23 October 2010, 20:26:08 »
Locate power sounder as described, hold the plug & pull  ::) :y
marke
  • manchester
Re: beeping noise
« Reply #8 on: 23 October 2010, 20:32:42 »
ha ha just read were it is located you sure i just pull :y
Re: beeping noise
« Reply #9 on: 23 October 2010, 20:48:03 »
more or less, I'm sure there'll be a clip you've to unlatch first .....  ;) ;) ;)
If you can't find it in the next fortnight & it's still not been in flames ....  ::) someone at Chester services will sort it for you  :y :y :y
Kneepad
  • West Scotland
Re: beeping noise
« Reply #10 on: 23 October 2010, 21:19:07 »
Don't be alarmed when you unplug it, this will usually activate it, but it will stop after a while  ;D
You could also try replacing the batteries inside it, then plug it back in. :y
skyblue
  • Bracknell
Re: beeping noise
« Reply #11 on: 24 October 2010, 23:17:51 »
[/b]
Is this a main dealer part only as I think mine is starting to go. Im getting this beep every now and then so I suspect that this is the cause. Im right in thinking once its disconnected the alarm system wont work if the car battery is disconnected
skyblue
  • Bracknell
Re: beeping noise
« Reply #12 on: 24 October 2010, 23:23:51 »
Just looked at another topic on this and have had my question answered  already.... must make a mental note for myself..... look at other topics before asking the same question :-[ :-[
Re: beeping noise
« Reply #13 on: 24 October 2010, 23:29:17 »
Don't worry about it, there's tons of info here to wade through. The complete power sounder is available from the dealers - £60ish IIRC - but changing the batteries requires a hacksaw to cut it open. I'm sure there's a how2do somewhere.  ;) ;) ;)
skyblue
  • Bracknell
Re: beeping noise
« Reply #14 on: 24 October 2010, 23:36:36 »
Thanks Andy. This has only started since I disconnected the battery a few wks back so It looks like im gonna be 60 quid shorter this month  :(
Dont know if Vauxhall fit these to all there cars ( daughter has a corsa and her  alarm never seems to go off  even if she leaves the window open.... so im thinking has this been removed  ???)
Page created in 0.131 seconds with 20 queries.
