Pages: 1 2 [3]  All   Go Down
Author Topic: Want to chiptune a omega 2.5 V6  (Read 13844 times)
jerry
Re: Want to chiptune a omega 2.5 V6
« Reply #30 on: 12 October 2010, 20:14:25 »
bit off tangent, but I had a dastek unichip fitted to my old prelude (which was an autobox vtec) which was remapped on a rolling road. Autoboxes are always  more difficult to map as accurately as manuals but I got improved power (nigh on extra 10%) with slightly better mpg. Of course the whole thing was retuned so that the vtec actuation point was lowered a bit and the fact that the mpg didnt decrease was probably down to the fact that Honda tend to run a bit rich in the first place. Overall, it was money well spent in terms of the amount of extra power I got per £spent-compared with what you get for the money you might spend on exhaust systems or induction kits for example. When I went to the same place to ask them about a dastek chip for my 2.5v6 auto omega however, I was told that 1)I wouldnt get the same sort of return that I got with the prelude (presumably because the mig isnt a vtec ) and that,2, as an autobox, it would be very hard to do(despite the prelude also being an autobox!). I phoned dastek and they said much the same-though stating that theyd done several very succesfull 2.5 manual Vectras. Seems like changing the cams is the way to go. :y
Java
  • Lund
« Reply #31 on: 13 October 2010, 10:11:34 »
Many people talk about changing the cam but talked to my brother regarding that and (hes a the new kind of mechanic. Plug in the computer, change the part) and he told me to really look up that the motors had the same technical specs. if I wanted to change cams, or it could go bad.
Lets compare 2.5 V6 and 3.0 24V, they both have 24V but does anything but the cam differ between them?
« Last Edit: 13 October 2010, 10:15:01 by Java »
From Java
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #32 on: 13 October 2010, 10:33:03 »
the 3.0 cams are a straight swap and reported to give 15 or so bhp extra due to the different profile used on the 3.0
other rides
« Reply #33 on: 13 October 2010, 11:38:29 »
Sounds advice but, to put your mind at ease:
a) Many people have put 3.0 cams in a 2.5 without any problems
b) GM actually sold a 2.5 V6 with these cams (in the Vectra SuperTouring 200 IIRC)
Java
  • Lund
« Reply #34 on: 13 October 2010, 12:36:19 »
Hmm sounds to good to be true. So no need to change sensors or anything like that?
From Java
« Reply #35 on: 13 October 2010, 18:45:31 »
Java - no need to change anything else, just pop the 3.0l cams in. But use a torque wrench!!!
You get a better boost that the (mor expensive, normally) chip route :y
Or do both...
Java
  • Lund
« Reply #36 on: 13 October 2010, 20:16:06 »
Like I said, bought a chip and looking for camshafts now so lets see if I'll manage to put in a new camshaft. I presume its hard as hell for someone with no talents, right?
« Last Edit: 13 October 2010, 22:53:22 by Java »
From Java
Sixstring
  • Lydney, Gloucestershire
« Reply #37 on: 14 October 2010, 14:41:08 »
No, easily within the scope of a d.i.y orientated person.
If you are unsure or not confident enough, Darth Loo-Knee, or many others on here will happily do it for you for folding beer vouchers!!
*edit* dunno where "Lund" is, and seeing you call an estate a caravan, assume not in UK. This job is relatively easy, you must get the torque settings for the parts you need to remove, but the last ones I personally did took me about a whole day to do, from drive in to drive off. The Haynes or other manuals have a good section on pictorial assembly, so would buy one of those publications. Essentially you should have a good torque wrench, and a socket set including "torx" male and female types of sockets.
Take a deep breath, its really not that difficult.
« Last Edit: 14 October 2010, 14:45:27 by Sixstring »
« Reply #38 on: 14 October 2010, 14:49:32 »
You spotted it but yeah, I'm not sure DLK would be up for a trip to Sweden just to fit some cams ;)
(Or he might, you never know! ;D )
Java
  • Lund
« Reply #39 on: 14 October 2010, 15:07:41 »
Lund my friend is a city in Sweden, very close to Malmoe if that rings a bell. Well I will have to give it a try all though I won't do it myself. Hopefully will my father-in-law help me out. Thanks everyone for your great responses. I will come back when I've both chipped and fitted the new cams into the car!  :y
From Java
Sixstring
« Reply #40 on: 14 October 2010, 15:23:30 »
HaHa! yep, I know where Malmo is..........
just take your time, and I'll look forward to your posts when it is done.
Good Luck!!
« Reply #41 on: 15 October 2010, 21:41:55 »
Nice heliport in Malmo - used to fly in there from Copenhagen and pick up a rental car :y
Java
  • Lund
« Reply #42 on: 28 October 2010, 11:28:18 »
I'm back, right now I've taken out the box and located the chop which I want to replace. There is one small problem, it has a yellow plastic shell around itself. Should I break it of or should I be careful so I can reuse the shell?
Edit: Got it of and put the new chip on. Cant really say yet that I can notice any "lower" fuel consumption. I my world, it seems like the car goes faster and consumes more but I don't know...
Will that chip be "confused" when I've inserted the new camshaft from X30XE motor? Since the chip is designed for X25XE so to say, or?
« Last Edit: 28 October 2010, 13:59:40 by Java »
From Java
deviator
  • Chesterfield
« Reply #43 on: 28 October 2010, 15:54:06 »
Might I add, if you want economy and not performance.
Try J cams not G cams.
I believe J are the mildest cams available for the v6 engine and are part of the standard 3.2 sri vectra C setup.
Java
  • Lund
« Reply #44 on: 28 October 2010, 18:12:31 »
The point of the cams were performance but the chip said to be economic which is why i presumed that it should be cheaper, if I get more power thats fine by me :)
From Java
Pages: 1 2 [3]  All   Go Up
Page created in 0.051 seconds with 20 queries.
