Author Topic: abs light  (Read 3416 times)
charlie
  • sunderland
abs light
« on: 30 October 2010, 18:08:27 »
Would running the car on ramps put the abs light on?Ie front wheels not turning but back wheels are .Cheers chalie ;D ;D
« Last Edit: 30 October 2010, 18:08:51 by charlie »
Re: abs light
« Reply #1 on: 30 October 2010, 18:10:54 »
It did on my 'new' Astra (2000 TD) Try it and let us know  ::)  ::)  ::)  :y
charlie
  • sunderland
Re: abs light
« Reply #2 on: 30 October 2010, 19:14:40 »
To late andy ran car on ramps and then in gear and abs light came on ,How do you turn this light off :'(
Re: abs light
« Reply #3 on: 30 October 2010, 19:46:34 »
I turned mine off with my 'Cheapo Tech II' but when I asked about this last week, Entwood said that the ABS light had come on his(?) car after 'playing' doing wheel spins etc and the light went off on its own after a few miles of normal driving.
Take it for a spin ....... with your fingers crossed.  :y
vauxfan2k
  • Western Isles
Re: abs light
« Reply #4 on: 30 October 2010, 21:12:54 »
its should go out by istelf when you drive the car normally (4 wheels on the ground) if not then get the codes read  :)
Re: abs light
« Reply #5 on: 01 November 2010, 11:48:08 »
Yep, often comes up on a rolling road when the ABS ECU can't comprehend the back half of the car doing 140 MPH while the front half is stopped. ;D
The light will clear given a few runs, I suspect. Stored code might remain but will cause no problems.
charlie
  • sunderland
Re: abs light
« Reply #6 on: 01 November 2010, 17:01:38 »
Took the car of the ramps today(rain stopped at last) first run out the light went out straight out,so clutch complete abs light sorted.happy days :y
