Author Topic: Headlight mystery  (Read 2169 times)
DerekT
  • Cumbernauld
Headlight mystery
« on: 28 October 2010, 16:43:23 »
Hi folks,
I have an Omega 2.5 CDX on a W plate. Recently the D2S right halogen headlight went (or at least I thought it did). So I bought a new bulb and put it in and it still didn't work so I checked the fuse and it was blown.
Next I changed the fuse and put the old bulb back in and it blew the fuse. OK so it seems the old bulb is faulty and its blowing the fuse. So I put in a new bulb and a new fuse but this time the light comes on for a split second then goes off, the fuse does not blow. I can turn it on any number of times and the max the bulb will stay on is about 2 seconds. I even tried yet another new bulb and get the same symptoms.
What could be causing these bizzare symptoms?
Many thanks,
Derek
Welung666
Re: Headlight mystery
« Reply #1 on: 28 October 2010, 17:22:02 »
Most likely the ballast pack then :(
DerekT
  • Cumbernauld
« Reply #2 on: 28 October 2010, 18:13:13 »
Thanks a lot, I've just googled what a ballast pack is :)
Does anyone have a procedure for changing it?
Thanks again,
Derek
I_want_an_Omega
« Reply #3 on: 30 October 2010, 19:32:17 »
Don't you mean Xenon?
  • Auckland
    • Mazda MPV
« Reply #4 on: 30 October 2010, 21:09:57 »
Getting a sense of Deju Vu (deja moo?) here.
Xenon is one of the halogen gases.........
[edit]Bugger, xenon is a noble gas, not a halogen[/edit]
« Last Edit: 30 October 2010, 21:13:09 by andyh »
DerekT
  • Cumbernauld
« Reply #5 on: 02 November 2010, 14:54:15 »
Sorry, yes I mean Xenon. Not sure how noble it is, its a pain in the neck for me :)
I think I have to get the headlight out to the ballast pack but I cant even figure out how to do that.
Any advice would be appreciated.
DerekT
  • Cumbernauld
« Reply #6 on: 02 November 2010, 15:42:34 »
Guys,
With some brute force I got the headlight out and swapped the ballast pack. This time when I turned on the lights the fuse blew.
So new bulb, new fuse, new ballast pack
What now?
Many thanks,
Derek
tidla
  • solihull
« Reply #7 on: 02 November 2010, 22:25:07 »
had a drink, bear with me. put an amp meter on the bulb connection and turn on. should be nothing. if you get something then voltage/ amps is disappearing somewhere.?
edit (feed before the ballast pack)
« Last Edit: 02 November 2010, 22:31:27 by tapper888 »
DerekT
  • Cumbernauld
« Reply #8 on: 04 November 2010, 17:42:39 »
Thanks tapper, there is a voltage and also I notice that the sheathing is worn around the feed wire so copper is exposed. Its getting beyond my skills now so I've booked an auto electrician to have a look at it on Monday.
Thanks to all for your help.
Derek
