Author Topic: Re: Bose By-Pass  (Read 2428 times)
Re: Bose By-Pass
« on: 08 November 2010, 11:28:19 »
You will need to change all the speakers for 4 ohm ones!.
You should be able to disconnect the Bose loom in the driver's footwell, install a loop-back connector from a non-bose car, remove the fuse for the Bose amp feed and that should be it.
Re: Bose By-Pass
« Reply #1 on: 08 November 2010, 14:14:42 »
someone did not like that answer  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Bose By-Pass
« Reply #2 on: 08 November 2010, 14:19:13 »
Talking to yourself again Kevin!   ::)
Re: Bose By-Pass
« Reply #3 on: 08 November 2010, 14:20:56 »
I always find I get the most intelligent conversation that way.. ;D
zirk
  • Epping Forest
Re: Bose By-Pass
« Reply #4 on: 08 November 2010, 14:24:58 »
I wouldn't count on that, not if the word Bose is somewhere in the thread.  :)
« Last Edit: 08 November 2010, 14:26:46 by zirk »
Re: Bose By-Pass
« Reply #5 on: 08 November 2010, 14:31:09 »
No, but you can count on it being expensive, shiny and hyped beyond belief. :y
