Author Topic: Tcs abs lights on!?!?  (Read 2888 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 07 November 2010, 22:40:09 »
Was driving home Friday after having a puncture and the abs and Tcs lights came on.stopped the car restarted it and all was well,today they have come on again!so restarted and they went off but now come back on after a few min.what's causing it?anyone know? :y
scream if you want to go faster!!!
Re: Tcs abs lights on!?!?
« Reply #1 on: 07 November 2010, 22:46:23 »
Is the speedo still working OK, if it is its more than likely a sensor on one of the wheels, could even be dirt  ;)
« Reply #2 on: 08 November 2010, 08:50:08 »
My bet is abs ecu - starts that way mate :(
mr ICE man
  • dolgellau wales
« Reply #3 on: 08 November 2010, 10:01:29 »
everything else works fine!has only started after that puncture on motorway,i think it might be dirt but wanted to check!if it was ecu wouldnt the fault always happen?ive also been on a farm all weekend in lots o mud!will give a pressure wash and see
« Reply #4 on: 08 November 2010, 11:38:38 »
How bad was the puncture?
If the tyre came apart it could have torn a sensor wire off..
« Reply #5 on: 08 November 2010, 14:34:30 »
I suppose it's possible that the wheel diameter being wrong due to deflation might have upset the ABS/TC ECU?
Is the spare tyre the same size as the other tyres? I wonder if the rolling radius is different and still upsetting the ECU.
As said, loom for damaged sensor / wiring, especially if it doesn't go out after the original wheel has been replaced with a repaired / replaced tyre.
Page created in 0.057 seconds with 20 queries.
