Author Topic: Laptop Problem  (Read 2857 times)
JiMbOb789
  • Timaru, New Zealand
    • x4 Omegas
Laptop Problem
« on: 18 February 2008, 14:47:18 »
hello peeps,
     i'm having trouble with my laptop, it says that my CD Driver is broken. Its a Samsung NV25 Notebook. I went on the samsung website and they dont have a driver for the CD Drive.
How could this be fixed?
By the way, i am also on Vista if that makes a difference or not.
Here are some pictures.
Re: Laptop Problem
« Reply #1 on: 18 February 2008, 15:10:23 »
can you close it properly..
did you checked the sockets if visible..
did this happen after an install ?
Re: Laptop Problem
« Reply #2 on: 18 February 2008, 15:25:15 »
this seems likely to be hardware problem not software
blame it on the hardware rule ;)
« Last Edit: 18 February 2008, 15:40:20 by cem_devecioglu »
JiMbOb789
    • x4 Omegas
Re: Laptop Problem
« Reply #3 on: 18 February 2008, 15:41:28 »
Yes, i installed Magic Disc then i think it went then so then i got rid of it.
Re: Laptop Problem
« Reply #4 on: 18 February 2008, 18:07:17 »
General fix for this is to uninstall all CD drives (physical and virtual), reboot and let pnp sort it all out again.
Re: Laptop Problem
« Reply #5 on: 18 February 2008, 18:31:39 »
what kind of software is in that magic disk ?
Bo Bo
  • Coventry
Re: Laptop Problem
« Reply #6 on: 18 February 2008, 18:34:59 »
Blimey, that's what I'd try  :o
Re: Laptop Problem
« Reply #7 on: 18 February 2008, 18:55:26 »
Its the correct 1st port of call :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Laptop Problem
« Reply #8 on: 18 February 2008, 19:08:39 »
Magically makes your disk disappear by the look of things.
TuBy's new whipping boy.
Re: Laptop Problem
« Reply #9 on: 18 February 2008, 19:53:33 »
seems so ;D ;D
Re: Laptop Problem
« Reply #10 on: 18 February 2008, 20:32:32 »
correct procedure...lump hammer...house insurance  :y ;D
Re: Laptop Problem
« Reply #11 on: 19 February 2008, 00:38:18 »
On XP, and i believe Vista also, can lose cd drive(s) if certain makes of burning software uninstalled!
Micoshaft are aware and have fix on their web site which basically updates the registry - its called autofix.  If u've uninstalled this type of software try this 1st.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Laptop Problem
« Reply #12 on: 21 February 2008, 07:31:30 »
stands for Plug'N'Pray    :D
JiMbOb789
    • x4 Omegas
Re: Laptop Problem
« Reply #13 on: 21 February 2008, 19:44:37 »
Thank you very much peeps, i am pleased to say that it is now fixed! :) :D
I done what 'The Boy' said to do which was to uninstall all the CD drives and re-install them and now it is fine.
By the way, Magic Disc mounts files to CD's, can be very useful but some advice, when you uninstall it, your CD drive crashes so i wouldn't recommend it. :y
Thank you very much who helped me with my laptop problem, i really appreciate it,
Thanks,
Jamie
 :) ;) 8-) :y
Re: Laptop Problem
« Reply #14 on: 22 February 2008, 09:47:11 »
Thanks,
Jamie
 :) ;) 8-) :y
daemon tools is my prefered virtual cd drive - usually very stable
