Pages: 1 [2] 3  All   Go Down
Author Topic: Tow bar, reversing sensors, and bleepin indicators  (Read 6566 times)
Re: Tow bar, reversing sensors, and bleepin indicators
« Reply #15 on: 17 November 2010, 21:15:52 »
Speaker lead has a little connector half way along the wire ... just at the top of the boot area ... mine is presently unplugged to stop the "fail" noise driving me mad .... might be the previous owner has done the same ??
« Reply #16 on: 17 November 2010, 21:27:19 »
By the 430 ohm fuse looking thingy? Mines purple by the way.  ;) ;D
« Reply #17 on: 17 November 2010, 21:32:03 »
my 430 Ohm is just to the left of the boot slam panel ... by the rear light cluster. The speaker is right up under the rear left of the parcel shelf. ... pair of brown (I think) sheathed wires from the multipin plug on the parkpilot control panel head upwards in that direction .. mine were tagged to the very top "hole" by a small cable tie.... just behind that is a simple plug/socket .. obviously on the flylead from the speaker.  I've simply unplugged to stop the noise. When I wanted to test/diagnose all I did was plug back in !!
« Last Edit: 17 November 2010, 21:32:46 by entwood »
« Reply #18 on: 17 November 2010, 21:33:22 »
2 questions/observations spring to mind...
1) Who said curry?
2) In the UK, foglights are gay - we simply don't get the lack of visibility, yet every gay tinker turns them when visibility falls below 300 miles  >:(
« Reply #19 on: 17 November 2010, 21:36:20 »
....... yet every gay tinker turns them when visibility falls below 300 miles  >:(
and then turns them off months later when they notice a 'new' orange light on the dash  :-? :-? :y
« Reply #20 on: 17 November 2010, 21:44:09 »
Ah, so spare wheel out. I think I saw what you mean a couple of days ago when I had a brief look at it before rain stopped play. Square lump in the loom covered in foam wrap cable tied to the upright panel the unit is attached to...? If so it's not been disturbed by the looks....?
« Reply #21 on: 17 November 2010, 21:47:41 »
Thats about it ... wonder why you don't get any sounds at all then .. unless the speaker itself has been butchered .. or your control box is completely FUBAR ... :(
« Reply #22 on: 17 November 2010, 21:48:37 »
On the bike I used to pull up by the drivers window and ask " what's that rather great orange light on your dash?" and without fail there was a surprised "oh" and a press of the button to turn them off. Some times weeks after any possible fog  >:(
« Reply #23 on: 17 November 2010, 21:54:24 »
No power maybe?  Is there a plug to the unit? Could not find a related fuse in the in car fuse box
 diag  :-/
« Reply #24 on: 17 November 2010, 21:57:01 »
 diag  :-/
*cough* get a meter out *cough*
« Reply #25 on: 17 November 2010, 22:03:04 »
Sounds like a job for the car park of the curry house to me. :P :y
« Reply #26 on: 17 November 2010, 22:06:31 »
 diag  :-/
I'll unscrew the unit from the metal panel tomorrow and see if I can see anything obvious, it a bugger to see in behind there, meter out and possibly pinch the unit off the other car, which works fine. But looking at some of the cable ties, somebody has been buggering about in there, possibly to fit the bleeper for the indicators maybe.
« Reply #27 on: 17 November 2010, 22:18:18 »
Not gonna quote the whole thing above !!!
I had assumed you'd had the control box out .....  but it has two multipin connectors going to it ... one has all the wires from the sensors themselves, the other the power/speaker/test/430 Ohm/ and two that when connected make it quiet, when open loud (I think) ... there are bits in TIS
KTA-176800029327 - diagnostics procedure
KTA-176800029328 - for loom/plugs
HTH
« Reply #28 on: 17 November 2010, 22:19:27 »
Sounds good to me  :-* getting hungry now  ::)
« Reply #29 on: 17 November 2010, 22:20:18 »
HTH
Don't set TIS for 2003 model - it won't find above docs!  :-[
Pages: 1 [2] 3  All   Go Up
