Author Topic: car Battery removal  (Read 2300 times)
zirax
car Battery removal
« on: 28 November 2010, 14:09:37 »
Following on from the aux belt failure, the battery has died. I know it isn't as simple as disconnecting the terminals and refitting. I can remember some steps (below) but I can't for the life of me find the info again. What I remember is
1. Turn on the ignition, then turn off.
2. Within 15 secs disconnect the negative terminal, then positive.
3. Refit battery
4. See if it runs.
Is this right? I imagine the powersounder will probably go off as well.
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
Re: car Battery removal
« Reply #1 on: 28 November 2010, 14:11:24 »
3. Refit battery
4. See if it runs.
that's correct, if you do as you've posted, then the powersounder won't sound.  :y
vauxfan2k
  • Western Isles
« Reply #2 on: 28 November 2010, 14:11:56 »
if the battery is already stone dead, then the proceedure doent need to be followed, just connect a new battery, and have the keyfob at hand to deactivate the alarm if it goes off.
zirax
« Reply #3 on: 28 November 2010, 14:13:02 »
Brilliant, thanks :D I thought I was going mad  :y
edit: not totally dead but not far from it, very slow warning siren when checking the battery by turning on the lights. Wouldn't turn over etc. Thank you
« Last Edit: 28 November 2010, 14:14:36 by zirax »
