Author Topic: eml constant flashing  (Read 1831 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 03 December 2010, 16:38:47 »
i have a problem with the ignition key. my solution was remove the brass tumblers & reinstall the barrel in situ, did it but the car still doesn,t start. i just got a constant flashing from eml. i have a new ign barrel coming(tuesday)& my idea was to start the car in the meantime. any ideas out there. :-/ :'(
Re: eml constant flashing
« Reply #1 on: 03 December 2010, 16:40:22 »
Check the chip is still in place in key and check that the connector on the transponder ring is secure
« Reply #2 on: 03 December 2010, 16:48:19 »
As RobG says, something has upset the immobiliser...
trem
« Reply #3 on: 03 December 2010, 16:59:54 »
you haven't disturbed the immobilser ring on the barrel have you, if thats damaged it will never start, not sure on the alarm system on vx's but i know renaults and peugeot/citroen have this system.
Have you checked the connections to the ecu, is the plug seated all the way home, is the battery fully charged, had the car gone into 'shut down', i know some do if they haven't been started in a while.
raywilb
    • Citroen C4 Cactus
« Reply #4 on: 03 December 2010, 19:39:25 »
thanks guys you v,e got it right. i had not put that immobiliser jobbie back. started ok once done . thanks once more :y :y
« Reply #5 on: 03 December 2010, 20:18:30 »
Phew! Easy fix then  :y :y
