Author Topic: windscreen wipers  (Read 3528 times)
paul36uk1
  • midlands
windscreen wipers
« on: 29 November 2010, 19:14:07 »
hi i have a 2001 omega mv6,windscreen wipers stopping in middle of screen all of a sudden,they work fine just finish in the middle,
any ideas?    cheers
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: windscreen wipers
« Reply #1 on: 29 November 2010, 19:20:19 »
do they do a full sweep? are they any slower than usual? sometimes the nuts holding them to the car work themselves loose, might not be this but worth a look  :y
« Reply #2 on: 29 November 2010, 19:28:08 »
any ideas?    cheers
Who's been switching their frozen wipers on without defrosting?  ::) ::) ::)
As freind61 says. The motor has an arm bolted to it that connects to the rest of the wiper linkage, it's this nut that's come loose. Remove wiper arms, and then the plastic scuttle to gain access to the wiper motor. There are 4 self tappers holding the complete assembly to the car, undo these and remove the lot from the car, be careful of the paint on your driver's wing. There are marks on the ally casting that the motor bolts to >    < the arm should sit between these marks.
fiend61
  • york
  • each to their own
« Reply #3 on: 29 November 2010, 19:30:40 »
freind??????  ;D ;D ;D :D :P
« Reply #4 on: 29 November 2010, 19:40:29 »
Oh yes! Fraudulent slip!  ;D ;D ;D ;D ;D
Kneepad
  • West Scotland
« Reply #5 on: 29 November 2010, 19:44:15 »
Better than Fiend.   ;D
« Last Edit: 29 November 2010, 19:44:34 by Kneepad »
fiend61
  • york
  • each to their own
« Reply #6 on: 29 November 2010, 19:49:34 »
freind------fiend-------  doesnt really matter i answer to all--- usually "OIII stop playing with that bloody car" ;D ;D ;D
Welung666
« Reply #7 on: 29 November 2010, 20:19:39 »
Think yourself luck Fiend... I get letters added to mine too, but they appear much worse than 'friend' ;D ;D ;D
fiend61
  • york
  • each to their own
« Reply #8 on: 29 November 2010, 20:55:27 »
yup i have seen, thought that would have been a compliment  :o :o ::)
fiend61
  • york
  • each to their own
« Reply #9 on: 29 November 2010, 20:56:14 »
err quick re-phrase I HAVENT SEEN  :-[ :-[ ;D
Welung666
« Reply #10 on: 29 November 2010, 21:04:28 »
 ;D ;D ;D ;D ;D
Kneepad
  • West Scotland
« Reply #11 on: 29 November 2010, 21:49:18 »
 ;D ;D ;D ;D ;D
 ;D ;D ;D ;D ;D LMAO.
paul36uk1
  • midlands
« Reply #12 on: 29 November 2010, 22:06:25 »
thanks fiend61 and andy b  :y
o mega man
« Reply #13 on: 03 December 2010, 20:30:03 »
Just used your advice thanks chaps and fixed my wipers. I bust them yesterday and they were resting in the middle of the screen when turned off.
I've got a 2.0cd ( yr 2000 ), Ididn't need to mess about taking all the wipers and scuttle thingy off, I got access from the engine bay ok. It was a bit of a fiddly  ;Dgaenacology job, but if you turn the wipers on and stop them at the top of the cycle using the ignition key it makes access easier.
Ta chaps
Kneepad
  • West Scotland
« Reply #14 on: 03 December 2010, 20:56:34 »
Ta chaps
Good tip there.   :y  Welcome to the forum.  :y
