Author Topic: Unable to enter code for radio.  (Read 7394 times)
vauxfan2k
  • Western Isles
Re: Unable to enter code for radio.
« Reply #15 on: 14 December 2010, 18:35:06 »
if you have stereo removal keys, pull the unit out and check the fuse on the back of the unit. failing that check if the wiring has been altered by any previous owners while its out.
its a power related problem preventing you getting the unit to prompt for the code by the looks of it
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #16 on: 14 December 2010, 19:27:11 »
OK, if previously functioning before battery issues, then would suspect fuses.
The display should be coming on and showing something, even if other functions - possible bulb failure, more likely blown fuse somewhere.
Stereo should show some signs of life when switched on, if not, again check main fuses, and also the one on the rear of the head unit.
Radio & Decoding Technician
www.dndservices.co.uk
steve66
« Reply #17 on: 14 December 2010, 21:30:52 »
This is for Dave DND
We have a similar problem with our radio CCRT 700 only it says safe and we have tried all methods to put the code in and it won't work, all were working b4 a battery change,now it won't even respond, please help
vauxfan2k
  • Western Isles
« Reply #18 on: 14 December 2010, 21:33:48 »
Best start your own new thread bud, save hijacking this one. and keeps it tidy.  :y
« Last Edit: 14 December 2010, 21:34:06 by Vauxfan2k »
Martin Nash
« Reply #19 on: 14 December 2010, 21:46:32 »
Many thanks will purchase the stereo removal keys so as to remove unit and check the fuse.
