Author Topic: Help needed with wiring codes to EGR on 2.2 petrol  (Read 6003 times)
DaveL
  • Nr. Cupar, Kingdom of Fife
« on: 13 December 2010, 15:38:40 »
Hi all,
Needing help identifying the wireing colour codes into the plug on the EGR on a 2.2 petrol engine. The car is a MY 2000  with the y22 engine.
Welung666 sent me a plug and part of a wiring loom. However the wires on this plug are not the same as the wire colours in my car's loom. Once I know which wires go to which pin on the plug I hope the Omega will be back on the road.
DaveL
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Help needed with wiring codes to EGR on 2.2 petrol
« Reply #1 on: 14 December 2010, 02:39:27 »
what wire colours do you have??
Solar charger fitted.
If not Broke dont fix it..
DaveL
« Reply #2 on: 14 December 2010, 06:10:44 »
Sorry I have not replied earlier, will have a look when it is light.
DaveL
DaveL
« Reply #3 on: 14 December 2010, 09:18:29 »
Wires in loom on car:-
Brown/ Red tracer.
Brown/ White tracer.
White.
Red/ Blue tracer.
Red/ White tracer.
Wires on plug from Welung 666
Pin A.  Brown/ Grey tracer.
Pin B.  Brown/ Green tracer.
Pin C.  Brown/ Yellow tracer.
Pin D.  Black/ Blue tracer.
Pin E.   Red/ Blue tracer.
Hopefully some one will be able to give me advice as to which wires to attach to which.
Thanks,
DaveL
freecall666
« Reply #4 on: 14 December 2010, 16:01:17 »
I will ask around is the egr the same type as old one or newer or older??? on the plug there is a code like abcde and on old plug should have the same.. they should match up.
DaveL
« Reply #5 on: 14 December 2010, 21:05:40 »
Unfortunatly the original plug was completely smashed off, long story. So do not have old plug. ::) The replacement plug/wiring is different colours to the wires in my loom to egr, as seen by my list of wires.
DaveL
DaveL
« Reply #6 on: 14 December 2010, 21:07:48 »
The EGR is identical to the one taken off.
Thanks for your reply, could not contact earlier as I am having to do Hospital visits.
freecall666
« Reply #7 on: 14 December 2010, 21:21:21 »
Brown/ Red tracer.  B  Brown/ White tracer.  C    White.  ARed/ Blue tracer.  E  Red/ White tracer.D
Thanks,
DaveL
would think its that if wire's same as 2.0L egr colour code
« Last Edit: 14 December 2010, 21:23:45 by freecall666 »
DaveL
« Reply #8 on: 15 December 2010, 09:55:11 »
Thanks,
DaveL
Thanks for that  :y
Will try your selection and let the forum know, will probably take some time with other factors going on in my life at the moment.
DaveL
