Author Topic: is this normal CDR2005  (Read 2010 times)
mantagte
  • great yarmouth
    • omega bmw maverick
« on: 09 December 2010, 19:43:43 »
2001 facelift with CDR2005 fitted
the unit does not switch off when you remove the ignition key
but when you open the door it does switch off
is this right?
Re: is this normal CDR2005
« Reply #1 on: 09 December 2010, 20:03:19 »
No - it should go out when the key is removed from ignition.
mantagte
  • great yarmouth
« Reply #2 on: 09 December 2010, 21:22:53 »
any ideas :-?
Kneepad
  • West Scotland
« Reply #3 on: 09 December 2010, 23:53:44 »
You could try reprogramming it for Ign Key Logic and see what happens. :-/
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 11 December 2010, 08:46:07 »
Sounds like the front fascia may have been inadvertantly pulled off at some stage and has been badly refitted with not all of the connections making good contact
Radio & Decoding Technician
www.dndservices.co.uk
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 15 December 2010, 20:01:34 »
It's setup. It's described on the manual of the unit. You can turn it so that i tgoes off with ignition or you can select to ONLY use the power button. Links to Manuals should be available from the forum....I've seen them... Dunno where... In the glovebox?
