Author Topic: Field of Vision (FOV) headlight range problem  (Read 7410 times)
TQ
Re: Field of Vision (FOV) headlight range problem
« Reply #15 on: 30 November 2010, 23:51:17 »
Hi, I have been thinking, what if it pops off again. Sounds like a good fix to me. Thankyou for your input.  :)
Boditza
  • Craiova, Romania
« Reply #16 on: 02 December 2010, 15:20:51 »
a little retrofit question.. will i be able to retrofit on my facelift headlight adjusters from an 1999 omega?? they are slightly different
our_house
« Reply #17 on: 05 December 2010, 21:11:36 »
Hi all,
Is there definately two sensors? I can see the one at the front, and that's looks OK. I can't see the one on the back, has anyone got a photo?
Is there any way of checking these are working? all th bolts, screws etc on the front one are solid as a rock, so I can't see i'm going to get it off without breaking it.
Alternatively, is there any way of fooling the system into sticking the lights in the middle?
thanks
« Reply #18 on: 05 December 2010, 21:30:38 »
Hi all,
O course we're sure  ;). A duff sensor looks the same as a good sensor  ;) It's on the rear radius arm, towards the front, it's exactly the same sensor, just different bracket.
...Is there any way of checking these are working? all th bolts, screws etc on the front one are solid as a rock, so I can't see i'm going to get it off without breaking it.
You need a code reader to determine exactly what has failed. Soak everything in a GOOD penetrating fluid ie Plusgas a couple of days before you start.
.... Alternatively, is there any way of fooling the system into sticking the lights in the middle?
thanks
Pass  :-/ but I doubt it
« Last Edit: 05 December 2010, 21:31:25 by Andy_B »
« Reply #19 on: 06 December 2010, 08:33:56 »
our_house - consider filling out your profile, somebody nearby may be able to assist with code reading ;)
Boditza
  • Craiova, Romania
« Reply #20 on: 07 December 2010, 06:21:35 »
just fixed my omega headlight adjuster.. it was nothing wrong with it :)). two inches from the socket probably a mouse chewed on the wire and it was snapped :D. i even bought some adjusters from a breaker  :'(. check for your wires too when this happens.  ::) :y
Kneepad
  • West Scotland
« Reply #21 on: 07 December 2010, 09:04:23 »
That's a result.   :y :y
Boditza
  • Craiova, Romania
« Reply #22 on: 07 December 2010, 09:25:12 »
yes it is.. and its been bugging me for a year but untill i took the matter into my own hands no results came off :P
Kneepad
  • West Scotland
« Reply #23 on: 07 December 2010, 09:47:41 »
If you want it done properly..... Do it yourself.   :y
our_house
« Reply #24 on: 11 December 2010, 18:28:23 »
Have checked both sensors and they both look OK, checked the wires and connections and they look good. Checked the fuses and they're OK.
Does anyone know where the other end of the wires go, so I could check them?
How do the sensers work? are they just a variable resistor? how could I check them with a multimeter?
or any other ideas?
I am in Lancing in West sussex...if anyone has a code reader???
thanks
Boditza
  • Craiova, Romania
« Reply #25 on: 11 December 2010, 19:07:30 »
on facelifts the arm just pops out and its a magnet..
« Reply #26 on: 11 December 2010, 21:10:37 »
.... and they look good.....
Looking good isn't a measure of actually being OK  ;)
billy no mates
  • Central Scotland
« Reply #27 on: 16 December 2010, 22:34:52 »
[/quote]Looking good isn't a measure of actually being OK  ;)[/quote]
I use this method every morning to 'check' myself  :)
« Last Edit: 16 December 2010, 22:35:32 by nikconnor »
