Author Topic: washer bottle level sensor  (Read 1737 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« on: 29 December 2010, 07:31:33 »
just a quick one, the above what sort of fitting is it into the bottle? screw? part turn? pull out?
tried allsorts but bl**dy thing is refusing to budge  >:(
Re: washer bottle level sensor
« Reply #1 on: 29 December 2010, 09:21:39 »
Isn't it just a push fit into a rubber grommet? The actual switch is something like this ..... http://shop.ebay.co.uk/i.html?_kw=vauxhall&_kw=screen&_kw=pump&_dmpt=UK_CarsParts_Vehicles_CarParts_SM (but without the screw thread at the back  ;))
« Last Edit: 29 December 2010, 09:22:04 by Andy_B »
fiend61
  • york
  • each to their own
« Reply #2 on: 29 December 2010, 09:49:23 »
i was looking at this and looks like a push fit but mine wont budge  >:(
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-WASHER-BOTTLE-LEVEL-SENSOR-GM-90-346-056-/350252202494?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item518ca879fe
maybe abit more "UMPPH" required  ;)
unless others know any different  :-?
dont want to break bottle  :'(
« Last Edit: 29 December 2010, 09:50:31 by fiend61 »
« Reply #3 on: 29 December 2010, 09:53:11 »
maybe a kettle of hot water over the grommet will soften things up enough to make it let go.  ;D
fiend61
  • york
  • each to their own
« Reply #4 on: 29 December 2010, 09:56:00 »
hmmmm  :y
means i can have a cuppa too, will give it a try
cheers andy :y
