Author Topic: Heated seats problem  (Read 9565 times)
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
Re: Heated seats problem
« Reply #15 on: 29 December 2010, 11:38:48 »
I found a circuit diagram on another source which may help.
The person posting it said it was from TIS, would I be ok to post it here?
It has helped me retro-fit heated seats in a GLS where the wiring does not already exist. :y
I used to know everything. Then I got married.
« Reply #16 on: 29 December 2010, 12:26:56 »
kev checked 29 on mine with seats on, no power to that either, well 0.2 volts or similar. Not sure what 29 does? Although it's clearly heated seat related.
Fuse 29 feeds the heated seat switches but i suspect the signal from them only feeds the control unit in the seat. Power for the heaters comes from somewhere else, probably the main feed into the seat for the motors. Can't remember which fuse that is fed by.
Don't know what I was smoking last time I looked at the wiring diagrams but the power feed to the heaters appears to be from fuse 15.
