Author Topic: washer level  (Read 5110 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: washer level
« Reply #15 on: 03 January 2011, 22:14:07 »
Check the multiplug underneath the expansion bottle is firmly pushed home :-/
Would this have been removed for the head gasket work to be done, as mine has only started doing this since I had work done on the car...
yes, it would get more room to get to bolts... its only cliped in. lift up the bottle and have a look.
Solar charger fitted.
If not Broke dont fix it..
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: washer level
« Reply #16 on: 03 January 2011, 22:15:29 »
you have lost me vamps  :(
my original post was the washer bottle not coolant bottle  :y
freecall666
Re: washer level
« Reply #17 on: 03 January 2011, 22:19:33 »
well it is only water ;D ;D ;D
fiend61
  • york
  • each to their own
Re: washer level
« Reply #18 on: 03 January 2011, 22:27:01 »
well 50/50 mix antifreeze
       50/50 mix screenwash
so only 50% water but yes water all the same  ;D
just different bottles different uses and different locations  ;D
maybe that was causing the original problem i had them mixed up (not) ;D ;D ;D ;D
freecall666
Re: washer level
« Reply #19 on: 03 January 2011, 22:32:56 »
my rad not got tap water in, water bot wounder why the dont put heater in the bottle as the have them in the jets???
fiend61
  • york
  • each to their own
Re: washer level
« Reply #20 on: 03 January 2011, 22:35:12 »
that would be a good idea  :y
freecall666
Re: washer level
« Reply #21 on: 03 January 2011, 22:37:45 »
may have to make one ;D ;D got some heater rods 12v to  16v, should not be that hard. ;D ;D ;D
Re: washer level
« Reply #22 on: 03 January 2011, 22:39:30 »
My question is the same as yours, just with Omegas there is never a straight answer to a problem, you have to go around the houses to sort them ::) ::) ::)
In essence it needs an electrical circuit to work, if this is broken then the warning will show, low washer fluid.. :)
fiend61
  • york
  • each to their own
Re: washer level
« Reply #23 on: 03 January 2011, 22:45:49 »
yup vamps you are correct but my question was that the washer level warning was coming up only on turning off the ignition not on start up or car running and as the float switch is only on/off if the float switch was faulty it wouldnt be making/breaking the contact therefore would show warning all the time
anyways changed float switch again and now all seems fine  :y
Kneepad
  • West Scotland
Re: washer level
« Reply #24 on: 03 January 2011, 22:55:03 »
yup vamps you are correct but my question was that the washer level warning was coming up only on turning off the ignition not on start up or car running and as the float switch is only on/off if the float switch was faulty it wouldnt be making/breaking the contact therefore would show warning all the timeanyways changed float switch again and now all seems fine  :y
IMO the error would not show all the time, If you have an open circuit tail light the ecu notes this and you are reminded about it after you switch off.
