Author Topic: wiring in a cb radio  (Read 3236 times)
bellers
« on: 06 January 2011, 22:53:03 »
i got myself a cb and have it plugged into cigarette lighter but im getting alot of noise through it. has anyone go one wired in?
is there an empty slot in the fuse box i can use or a easy way through the bulkhead?
thanks
jonny
Welung666
Re: wiring in a cb radio
« Reply #1 on: 06 January 2011, 23:03:09 »
I've got a chicken box and a Zetagi 606 wired in to mine. 4mm twin cable direct off the battery with a 20a fuse inline on both lines about 2" from the battery. They are through the large rubber grommit near the pollen filter. Cable run is down behind the glove box and under the centre console and out under the drivers seat. A cigarette lighter plug from the rear plug into a 5 pin relay which shuts off the rig and linear when the ignition goes off. Fairly simple to wire up.
10.4 :y
bellers
« Reply #2 on: 06 January 2011, 23:17:04 »
thanks welung ive a cobra rig and will sort the wiring out at weekend as its hard to hear people with so much noise and every time i rev the car it gets worse.
would turning of the cb not be ok instead of wiring in the relay?
Welung666
« Reply #3 on: 07 January 2011, 05:53:01 »
I've just binned a cobra UK29, had it since new and it gradually died on the RX to the point where I couldn't hear anything. I'm on the hunt for a President Jackson 2 now.
Yes you can just turn it off, I only wired it this way incase I forget to turn the burner off and kill the battery on the car :y
« Last Edit: 07 January 2011, 05:54:04 by Welung666 »
« Reply #4 on: 08 January 2011, 00:02:54 »
That takes me back, I have a President Teddy R in the garage somewhere, an old AM set....10-4.. ::) ::) ::)
Welung666
« Reply #5 on: 08 January 2011, 08:42:08 »
That brings back some memories! My first homebase was a Teddy R on AM. I think it's still at my moms house along with my 6 stage silver rod ;D
Been looking at the Jackson 2 and can't believe the prices! Over £200 for a used one  :o
bellers
« Reply #6 on: 09 January 2011, 17:32:19 »
used the rear lighter socket and far better. no need to run through bulk head now
Welung666
« Reply #7 on: 09 January 2011, 21:06:05 »
Glad that helped ;) Roger D, 10-4 and catch you on the flip side good buddy :y
P.S. Whilst up in Lincoln today I was playing a few of the local homebasers up ;D
bellers
« Reply #8 on: 09 January 2011, 21:46:52 »
10-4 thanks good buddy
are the likes of homebasers on fm?
« Last Edit: 09 January 2011, 21:47:22 by bellers »
Welung666
« Reply #9 on: 10 January 2011, 05:50:23 »
Yes, all on 19 now though, that's who got the abuse yesterday ;D
Radiomarko
  • Sunny Devon
« Reply #10 on: 10 January 2011, 15:05:40 »
Don't pull too much current from there though, you'll melt something. Standard 4W is Ok.
I hate seagulls.
