Author Topic: Brake lights stay on when headlights on  (Read 1679 times)
lordcubby
« on: 14 January 2011, 16:17:54 »
Hi All,
Sorry if this has been answered elsewhere, but I haven't found it.
My break lights (left, right and middle) stay on when the headlights are on.  Also the cruise control is intermittent and the sun lifts of its own accord.
Can anyone help?
Thanks.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Brake lights stay on when headlights on
« Reply #1 on: 14 January 2011, 16:24:17 »
try this for your sunroof -http://www.omegaowners.com/forum/YaBB.pl?num=1247486519
could also try a reset first which i think is -
go through open, close and tilt but keep switch pressed for a few seconds after it has travelled to its limit in each position :y
brake lights not a clue  :-/ nor your cruise but somebody will be along soon  :y
« Last Edit: 14 January 2011, 16:25:46 by fiend61 »
« Reply #2 on: 14 January 2011, 16:44:10 »
Can you try taking the brake light bulbs in the rear clusters out one at a time and re-checking? I wonder if one of these is feeding across from the tail light circuit to the brake light circuit. Does anything odd happen when you brake without the headlights on? Number plate lights or dashboard illumination coming on, for example?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 14 January 2011, 17:02:02 »
Ive seen a similar brake light problem when someone put an indicator bulb (one pin on base) into a stop/tail socket that was looking for a bulb with 2 pins.
If the car is new to you, or you have been playing with lights, its worth checking you have the correct bulbs fitted?
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #4 on: 14 January 2011, 18:51:01 »
Agreed... Check all the bulbs are correct and correctly fitted... Other thing to check is a sticky Brake Light Switch :)
