Author Topic: Bose amp wire diagrams  (Read 3152 times)
V6MILLS
« on: 16 January 2011, 15:07:16 »
Ok im not an omega owner but i have sourced the full bose system incl loom to retro fit into my vectra..
I need a diagram off the amp loom to retro wire this into my ncdr1100... As im aware the speakers wire to the amp first then amp to radio loom..
Thanks in advancd
I_want_an_Omega
Re: Bose amp wire diagrams
« Reply #1 on: 16 January 2011, 15:19:27 »
Get yourself a copy of the Haynes manual for the Omega. The manual covers the cars upto MY '99. In the back are two sets of wiring diagrams  - the later ones cover the Bose install and show you all the pin connections etc.
"should" be all you need. Good luck - Rob
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 16 January 2011, 16:06:47 »
Thanks in advancd
Pretty sure that Head Unit cant be configured to Bose Mode.
V6MILLS
« Reply #3 on: 16 January 2011, 16:35:41 »
Ncdrs "can" be configured for bose.....
Plenty of proof on google if u search ncdr1100 or ncdr bose
Yeh im aware the haynes manual has the diagrams was hoping someone could post them up here for me.. Saves me paying £20 for the manual for just 1 wiring diagram as i will never use it again after that.
Thanks
« Last Edit: 16 January 2011, 16:37:38 by V6MILLS »
charlie
  • sunderland
« Reply #4 on: 16 January 2011, 16:48:57 »
I dont have a manual at hand what do you need to know as ive done this mod my self :y
    • 530D M Sport, 330i Coupe
« Reply #5 on: 16 January 2011, 16:51:21 »
If you have the Bose loom to hand it's pretty easy to sus out.
The speaker wires are the standard colours, the outputs from the head unit are the same colours but in a hard plastic outer, red-white is the remote power on, red is +12V perm, Brown is earth and green white feeds the sub / subs.
Only difference is that the estate bose loom branches off under the rear seat and crosses over to the n/s for feeding the subwoofer in the boot space whereas the saloon has the wires under the parcel shelf to the two subs.
V6MILLS
« Reply #6 on: 16 January 2011, 17:52:40 »
It will probley all be so simple when i get the bose kit next week.  But whats gettin my brain the most is that speakers wire to amp first then from amp to speakers. So i would need to determan which set of speaker wires are for amp to hu and speaker to amp..?
« Reply #7 on: 16 January 2011, 17:55:56 »
TBH it's blatently obvious when you look at the loom!
V6MILLS
« Reply #8 on: 16 January 2011, 17:59:24 »
Perhaps it is . I dont have the set up yet. I will post back next week if im still stuck.
Thanks in advance
