Author Topic: Cooling Fan Temp?  (Read 2718 times)
Humpy
  • Tunbridge Wells, Kent
Cooling Fan Temp?
« on: 23 January 2011, 15:05:15 »
What temp should the radiator electric cooling fan cut in at? It's not for my 3.0 Elite, it's for my mates 2.5CDX, he reckons the fan never cuts in. We did try last weekend but it was so flipping cold I'm not surprised it didn't cut in! Any ideas? Is the top switch on the rad the fan one? Should be able to remove the plug and short the terminals to prove, yes? Thanks for any help.
Humpy
Re: Cooling Fan Temp?
« Reply #1 on: 23 January 2011, 15:29:30 »
Around 92deg iirc  :y
« Reply #2 on: 23 January 2011, 15:44:32 »
Some while back there was a post with a link to a way of testing all the fans by means of "jumping" the contacts in the aux fuse box (the triangular one by the battery) ... but I can't find it .. :(
If you need to change the switches this is the how-to ..
http://www.omegaowners.com/forum/YaBB.pl?num=1225543651
« Reply #3 on: 23 January 2011, 15:58:09 »
Some while back there was a post with a link to a way of testing all the fans by means of "jumping" the contacts in the aux fuse box (the triangular one by the battery) ... but I can't find it .. :(If you need to change the switches this is the how-to ..
This is a copy of the 'Fan Test'  :y
« Reply #4 on: 23 January 2011, 16:27:18 »
Thats the one .. where is the original so I can bookmark it please .. :)
Humpy
« Reply #5 on: 23 January 2011, 22:34:33 »
Thanks guys, I'll give it a go!
Humpy
« Reply #6 on: 23 January 2011, 22:46:34 »
it's in the download section of the ABS forum.  :y
« Reply #7 on: 23 January 2011, 22:59:37 »
Explains why I couldn't find it here then .. DOH !!!!   :)
Humpy
« Reply #8 on: 29 January 2011, 14:00:52 »
Chaps,
Just to let you know, did the tests with the printout  supplied, proved the fans all work, found one fuse blown, replaced and all seems to work now  :) Just got to fix his heater now!
Humpy
Page created in 0.026 seconds with 20 queries.
