Author Topic: Doors Dead Locked  (Read 2484 times)
Densum
  • north east UK
Doors Dead Locked
« on: 26 January 2011, 20:01:22 »
Hi, Has anyone got an electrical drawing for the Central locking system for my Omega 2.5 TD 1999 preface model. As it was locked and dead locked.  But on trying to open it nothing happened, only indicator warning lights flash. So i opened the drivers door by the Emergency method with the key as per manual. but then the hand book manual says that I should be able to lift any door latch and they Will open but isn't happening so I can only get in the drivers door using key manually. Battery fully charged, all other functions working , Fuse OK, changed Driver door locking motor still wont release other doors   Help needed please.
Welung666
Re: Doors Dead Locked
« Reply #1 on: 26 January 2011, 21:11:44 »
Is the light on the key fob coming on when you press a button?
If so, try a re-sync (Ignition on 2, press lock button. Doors should lock and unlock). If not, try a new battery in the fob.
If that doesn't work, check fuse number 20 under the steering wheel (middle row, far right (20a)).
« Last Edit: 26 January 2011, 21:12:33 by Welung666 »
emo
« Reply #2 on: 26 January 2011, 22:53:40 »
having same problem posted mine on general help some thoughts maybe helpful
Densum
  • north east UK
« Reply #3 on: 27 January 2011, 00:47:16 »
Yes ive tried all those wellung thanks anyway.
emo
« Reply #4 on: 31 January 2011, 13:19:36 »
both key fobs work as auto window closing works. SOOO 3 out of 5 doors don't won't unlock or lock inside or out alarm still works when i open drivers door and stop when key is turned in ignition  imobiliser ok starts runs ok any more ideas including stupid ones it stops me from going mad :-Xer
