STOP PRESS !! Vauxhall CCR2006 & CDR2005 Available
Started by Dave DND, 14 January 2011, 15:03:18
Dave DND
TB, have seen on German auction site a CANBUS simulator for putting a CANBUS Audi radio into an older NON-CANBUS car, and this £25 little box of tricks gives the ignition sense signal to turn it on and off. I`m going to have a play to see if it can be modified in any way for use on the Omega, but mention it in case you get to research it before I do.
I'm sure I've seen devices that will take other signals - vehicle speed, RPM, etc. and send the information on a CAN bus. Can't remember where I saw it or why I was looking though. ::)
It probably wouldn't be that hard to build something. Plenty of little microcontrollers have built-in CAN interfaces these days and the head unit would probably only be a "consumer" of CAN packets, so you probably wouldn't have to talk to it interactively, just simulate a subset of the packets that would be spat out by the rest of the car.
Hmm. another project to add to the pile. ::)
There are many interfaces out there advertising speed pulse, ignition, reverse etc etc, but 99.9% of then are for putting a NON-CAN stereo into a CAN car, exceptionally rare to see it the other way around - but if you do ever see anything that is Non-VAG, please point me at it
Radio & Decoding Technician
www.dndservices.co.uk
Dave DND
QuoteAhh.. It was this I was thinking of, and it does it the wrong way round. ::)
http://www.racelogic.co.uk/index.php/en/other-products/cantran
Yep, thats the wrong way round -
Someone on another forum has pointed me at this though
http://cgi.ebay.de/Universal-CAN-BUS-Interface-Zundung-Simulator-Auto-12V-/390276158670?pt=Autoteile_Zubeh%C3%B6r&hash=item5ade4594ce
According to the description that gizmo just simulates a 'switched live' when it 'guesses' that the engine is running based on how the permanent live voltage floats (I'm guessing it's really just looking for a voltage >12V).. is that what you're looking for in a CANbus headunit? I thought it was the other way around.. (you needed the CANbus 'on' signalling rather than just 12v presenting on a wire)
Seems to generate a switched 12v supply from a permanent 12v supply by sensing the noise level on the permanent 12v supply to detect ignition switching, so no CAN conenction. Smacks of a bit of a bodge to me. :-/
Dave DND
Ahh, OK. :y
Looks like it takes the ISO signals plus one additional wire. Hmm. I suppose most if it is on the ISO plug. Permanent and switched power, illumination power, speed signal. Perhaps with the addition of a reversing light feed?
Strikes me that most of the signals will be the same for any pre-CAN car, except the calibration of the speedo signal, I suppose.
The question is whether the CAN output is standardised or bespoke to VW, I suppose.
It is tempting to get a CAN sniffer and have a poke around.
Dave DND
QuoteAhh, OK. :y
This one seems to be bespoke to VW-CAN1, and does not appear to support the later 2nd generation of VWCAN2 head units
Martin_1962
QuoteSadly my/your recommendation for marine ply bathroom upgrade had it's legs removed in no uncertain terms.  >:(
Mrs. KW was sceptical at first, but it's really grown on her. ;D
So what has been done with marine ply?
The floor of the en-suite. 8-)
I really intend to have another bash with that CD70, but I've put all my CIDs somewhere safe. Very safe. So safe, in fact, that I......  :-[
QuoteI really intend to have another bash with that CD70, but I've put all my CIDs somewhere safe. Very safe. So safe, in fact, that I......  :-[
I have acid (or even a cid) you could play with, but i'll need it back, and needs depairing first. But it's pointless surely!
Martin_1962
I put MP on hte bathroom floor under the tiles after we ripped up the carpet
I suppose I could take the box of tiles up there. Then it'd technically be under the tiles. ::)
