Author Topic: Courtesy Light Issue  (Read 2050 times)
MG
  • Worcester Park
    • 1999 Elite Estate 2.5 V6
« on: 04 February 2011, 23:55:30 »
The front near side door switch does not operate the inside lights or puddle lights. However, if the drivers door is opened then all inside lights including the puddle light on the near side door illuminate normally. I have had the door switch out and checked it with a meter and it seems ok. Is there a box of electronics or a solenoid somewhere that might be faulty?
Much appreciate any help....  :)
Mel.
Re: Courtesy Light Issue
« Reply #1 on: 05 February 2011, 00:20:06 »
In a word no! Almost certainly the switch or wiring to it.
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 05 February 2011, 16:53:03 »
Yep, sounds like the switch, try swapping them over. If you are getting a replacement, remember that facelift are different to pre.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 06 February 2011, 12:51:50 »
Note it should be a two pin switch...
« Reply #4 on: 06 February 2011, 12:54:19 »
isn't that just the driver's door switch?  :-/
