Author Topic: Seat heater not working  (Read 4271 times)
AetO
  • Västervik, Sweden
« on: 30 January 2011, 16:28:28 »
Since we bought the car, the heater for the driver's seat has never worked at all. Passenger's no problem. Tried obvious stuff to no avail, fuses etc. Leather seat. This time of year improved with sheepskin cover  :y
Any ideas?
Boditza
  • Craiova, Romania
Re: Seat heater not working
« Reply #1 on: 30 January 2011, 19:05:22 »
common problem on the drivers seat.. hater pad needs replacement.
« Reply #2 on: 30 January 2011, 20:54:15 »
As Boditza says but, remove the seat & have a look. You might be lucky in the the burnt section appears obvious. I cut out a very small section of burnt element & re-soldered the wires, and so far 5 or 6 yrs later mine still works. I did the same for the Senator before it.
Have a look, it doesn't cost anything and if you can't fix it you have just wasted a little of your time.  :y :y
they're heavy though  :-?
« Last Edit: 30 January 2011, 21:00:35 by Andy_B »
Julian James
  • Birmingham
« Reply #3 on: 10 February 2011, 21:09:37 »
yep.  i have just done the same to both of mine!
although I used a bit of other wire in between.
Took photos too, and will do a How To in the next couple of days :)
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 10 February 2011, 21:15:42 »
We will look forward to that julian,leather i presume. :y
Julian James
  • Birmingham
« Reply #5 on: 10 February 2011, 21:46:12 »
yeah leather.
just followed advice really.  semi-bodge job.  hope it's worthy!
