Author Topic: FM transmitter for ipod...Which one?  (Read 5476 times)
Omega_Dan
« on: 10 February 2011, 19:40:51 »
Anybody got one or can suggest one? only want to spend £15 - £20 as im fed up with CD's all over the mig ;D
Mysteryman
Re: FM transmitter for ipod...Which one?
« Reply #1 on: 10 February 2011, 19:43:35 »
I tried several. Mostly crap I'm afraid.
Omega_Dan
« Reply #2 on: 10 February 2011, 19:50:03 »
Most of the reviews dont help :-/
Thanks for the move admins. never posted in electrical help before :y
twiglet
  • Norwich, Norfolk
« Reply #3 on: 10 February 2011, 19:54:18 »
General consensus on here is to get one from Dave DND. It's 35 quid, but it seems to get all round thumbs up from OOFers  :y
I'm sure someone will post up a link!  :y
twiglet
  • Norwich, Norfolk
« Reply #4 on: 10 February 2011, 19:56:09 »
Here you go...
http://www.dndservices.co.uk/am-88t.html
Omega_Dan
« Reply #5 on: 10 February 2011, 20:14:33 »
Here you go...
Cheers. More than what i wanted to spend but ill give it some thought :y
« Last Edit: 10 February 2011, 20:14:56 by Omega_Dan »
twiglet
  • Norwich, Norfolk
« Reply #6 on: 10 February 2011, 20:16:08 »
Here you go...
As is quite often the case, you get what you pay for...  :y
Omega_Dan
« Reply #7 on: 10 February 2011, 20:19:56 »
Yeah. Main benifit is that it is hidden and permanent. it does look good tbh.
twiglet
  • Norwich, Norfolk
« Reply #8 on: 10 February 2011, 20:22:48 »
Glad thats helped ya! Now Dave, commission??  :y
« Reply #9 on: 10 February 2011, 20:31:43 »
I've got a Griffin iTrip Auto(?)... Not too bad when in the UK, although ideally needs to be plugged into the rear cig lighter. Biggest downside is that it invariably needs tuning every time >:(
This one I think http://www.amazon.co.uk/Griffin-Ga22042-Transmitter-Charger-iPhone/dp/tech-data/B0043M5Y7A/ref=de_a_smtd
« Last Edit: 10 February 2011, 20:33:27 by Lazydocker »
« Reply #10 on: 10 February 2011, 20:41:05 »
Tell a lie... This is the one I've got and it's not compatible with iPhone which I got 3 months later ::) ::)
http://www.amazon.co.uk/Griffin-6190-TRPAUTOS-Transmitter-Charger-Smartscan/dp/B000WKPHHO/ref=pd_cp_ce_3
« Reply #11 on: 10 February 2011, 21:47:00 »
I have a iTrip, which works, though I've had better results from dave dnds one, despite its very limited frequencies
« Reply #12 on: 10 February 2011, 21:58:14 »
This was my concern, especially with the September road trip. Switzerland and Northern Italy were a complete nightmare as there were no completely "quiet" frequencies :o We went through every single one manually a couple of times >:( >:(
Ploppy
  • Norfolk
« Reply #13 on: 11 February 2011, 06:00:11 »
I use one from tescos, not as good as Dave DNDs , but only about £13, plugs into the bottom of your Ipod and has a charger lead to plug into the cigarette lighter point. Its good enough for me , so it charges the IPOD.
Hope that helps
Ploppy :y :y
andrew38
  • Farnborough, Hampshire
  • Insignia 2.0Cdti 163
« Reply #14 on: 11 February 2011, 10:15:50 »
I purchased an add on dab receiver with a wired FM transmitter which I play through my head unit. It has an input for an aux in which I dont use, my stereo has an SD card slot for my music but it should work well with an IPOD. I purchased it for £26.00 excluding DAB aerial from Dabonwheels the aerial was actually more expensive than the DAB unit, I think now its £29.00 but still a bargain. The clarity is great and the DAB is awesome as well.
« Last Edit: 11 February 2011, 10:17:11 by andrew38 »
