Author Topic: Headlight adjusters  (Read 2545 times)
KJO
  • Cork
Headlight adjusters
« on: 15 February 2011, 23:26:29 »
Can anyone tell me if it is possible to replace broken adjusters for xenon lights. If so where can they be obtained & any hints on how to fit same.  :-?
Re: Headlight adjusters
« Reply #1 on: 15 February 2011, 23:50:50 »
Did Rob not already give you the link?
http://www.omegaowners.com/forum/YaBB.pl?num=1271424451
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #2 on: 16 February 2011, 00:17:14 »
I wimped out and got another couple of lights and swapped them over. I thought, perhaps wrongly, too much hassle. Two complete lights with over £140.00 worth of bulbs in situ...£100 smackers.
« Reply #3 on: 16 February 2011, 00:32:46 »
you must have too much disposable cash.  ;) Either spend c£25 to fix what you already have or .............. £100 to hopefully permanently fix with 'new' parts.  ;) ;) ;)
Kaycee
  • Doncaster
« Reply #4 on: 16 February 2011, 09:41:18 »
at least you could experiment taking old ones apart and have em as spares or sell on
There is a tide in the affairs of man if taken at the flood will lead on to greater things
« Reply #5 on: 16 February 2011, 11:32:12 »
So, 25 quid for a permanent fix or 100 quid for something with the same weakness  :y
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #6 on: 16 February 2011, 14:01:04 »
BUTTTTTTTT.......got the bulbs also.
The idea of putting my headlights in the wife's oven to help remove the "glass" was FAR to scary a prospect to contemplate. She's South African....learnt VERY quickly NOT to invade her kitchen for ANY reason.
markrl
  • London
« Reply #7 on: 16 February 2011, 15:34:44 »
Theres no need to put them in the oven just go around the seam with a paint stripping gun on a low heat setting to soften up the sealent. The lens pops off very easily. The aluminium adjusters sold as replacements are excellent.
Sadly I then discovered the joke chroming on the reflector lens which peels quicker then a sunburnt albino.  >:( >:( >:(
These lamps really are a complete load of Sh*t.  >:( >:( >:(
« Last Edit: 16 February 2011, 16:15:46 by markrl »
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #8 on: 17 February 2011, 15:23:39 »
Yep I also wimped out putting my headlamps into the oven but did find using a hot air gun just as good.
As a tip get yourself a few slips of card or thin plastic to push under the various "tangs" that also help to hold the lens onto the body. Otherwise they keep springing back or snap off.
The sealant is like goo and sticks to everything. Try not to get any onto the reflective(mirror) surfaces. Like markrl I found that if you wipe them then the mirror surface easily comes away. Solvent takes it off even quicker!!
« Reply #9 on: 17 February 2011, 15:25:40 »
the reflective surface will come off if you look at it hard.  :-? ;D ;D
Carfix
« Reply #10 on: 17 February 2011, 15:31:14 »
Andy....you animal.  ;)
I wont even mention that you have to "polish it hard" to get a decent finish!!  :o
