Author Topic: Open window  (Read 6813 times)
jock.p
  • West Lothian
    • 2002 2.2 CD auto
Open window
« on: 10 November 2010, 11:20:12 »
Has anybody else had this problem?
The rear passenger side window seems to be opening by itself.
Three times since I got the car I have returned to find the window open by about an inch.It was definately closed when I left it. The central locking only works with the key, could this be linked to the problem? Any input is welcome :-/
mantahatch
Re: Open window
« Reply #1 on: 10 November 2010, 13:15:02 »
Not had the exact same problem, but I have had issues with a rear window which turned out to be the main switch on the drivers door.
Failing that I would suspect that some damp has got in somewhere and is causing a short which occasionally powers the motor, again suspect switch on either door.
Hopefully someone with greater knowledge will be along soon.
iainb
  • West Midlands
Re: Open window
« Reply #2 on: 10 November 2010, 13:30:14 »
There is a feature on most cars called Global Open.
What it means is if the interior of the car gets to hot the windows will drop about 1 inch but the car will remain locked.
It can be disabled in your case a tech 2 session may do it, but first you need to find out why yours is activating and why only 1 window does it.
Re: Open window
« Reply #3 on: 10 November 2010, 14:14:08 »
This isn't a feature I've ever found on an Omega. The Alarm/CL ECU can close windows and sunroof, and will do so if you hold the locking button down but I don't believe it can open them for ventilation. :-/
iainb
  • West Midlands
Re: Open window
« Reply #4 on: 10 November 2010, 14:43:46 »
http://www.archersofashby.co.uk/Mondeo/Technology/Global%20Closing/global_closing.htm
Your right about the Omega but other cars have added function's
But if the car has a fault it may just drop a window and I have seen countless number of cars that do just what this car does.
Thats why a Tech 2 session may just locate this fault
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Open window
« Reply #5 on: 10 November 2010, 15:08:47 »
I`m not aware of teh "Global Open" feature on Omega`s, or indeed any other Vauxhall.
I do recall however, that there was some form of water / flood detection feature on Vauxhall cars that woudl open the windows if the car became immersed in water - allowing the occupants to escape. But seem to recall also, that this opened the windows fully, not just one of them a little bit. Worth checking the flood sensor isn`t sat in a pool of water though?
Also, most Vauxhalls are fitted with a form of safety feature that if something is jammed in the top of the window when its closing, ie, kiddies fingers, then the window would drop about an inch to prevent you from injury.
May give a couple of ideas of where to start to look?
Radio & Decoding Technician
www.dndservices.co.uk
turboteeth
Re: Open window
« Reply #6 on: 10 November 2010, 19:04:09 »
funny you mention that because my rear o/s rear window has just started re-opening as i attemp to close it.
It gets all the way up then opens an inch or 2 so i have to repeatedly "stab" the button to close it  >:( :-[
turboteeth
Re: Open window
« Reply #7 on: 10 November 2010, 19:06:32 »
stupid question but we are talking electric windows here are we not? :-/
Re: Open window
« Reply #8 on: 10 November 2010, 19:11:40 »
your problem is that the glass is tight in the runner/channel, the anti-trap electronics thinks there's a hand or something trapped, hence it going back down a bit. Try lub'ing the channel, silicon spray   :y :y :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Open window
« Reply #9 on: 10 November 2010, 19:21:05 »
Definately 2nd that one  !!
jock.p
  • West Lothian
    • 2002 2.2 CD auto
Re: Open window
« Reply #10 on: 11 November 2010, 14:13:48 »
I'm getting that problem with the other rear window,I new about the anti-trap system so I'm not too worried about that,I'll try lubing it with silicon.My main concern is the window opening by itself.Thanks for the replies and suggestions.Keep them coming.
jock.p
  • West Lothian
    • 2002 2.2 CD auto
Re: Open window
« Reply #11 on: 27 December 2010, 12:02:48 »
It happened again while the car was parked up. Nobody was near it for 2 days but when I returned the window was down about an inch. Any theories?
the alarming man
  • medway kent
    • disco V8
Re: Open window
« Reply #12 on: 27 December 2010, 12:44:38 »
Global open lol...i have heard it all now..yeah let me have the windows open an inch so car crime can rocket...too much sprit at christmas i think.....ACPO would sumersalt with your ideas...lol
Kneepad
  • West Scotland
Re: Open window
« Reply #13 on: 27 December 2010, 14:40:56 »
I have had this exact problem, rear passenger window would open about an inch, this went on for about a week. I still have  no idea what caused it, but my solution worked.
I Left all windows open, got out of the car and locked it with the key, holding the key until all the windows were fully closed.
It hasn't happened again since doing this and that was three weeks ago. Might be worth a try.
jock.p
  • West Lothian
    • 2002 2.2 CD auto
Re: Open window
« Reply #14 on: 27 December 2010, 17:41:54 »
Thanks I'll give it a try.
