Author Topic: Omega 2.6 CDX auto fault code P1560  (Read 2356 times)
Mick2.6
« on: 26 February 2011, 11:56:23 »
Hi,
I keep getting this fault code coming up - P1560.  There doesnt seem to be much on google about it.  A few mention 'fuel pump - voltage'.....?  Can anyone help.
Thanks
Mick
Re: Omega 2.6 CDX auto fault code P1560
« Reply #1 on: 26 February 2011, 12:27:15 »
Cruise working OK :question
Mick2.6
« Reply #2 on: 26 February 2011, 12:46:21 »
No the cruise does not work.
« Reply #3 on: 26 February 2011, 16:43:27 »
You have cruise fitted and it doesn`t work or you don`t have cruise fitted :question
Mick2.6
« Reply #4 on: 26 February 2011, 17:24:50 »
Yes i have cruise fitted but it doesnt work.
« Reply #5 on: 26 February 2011, 18:15:07 »
Code relates to inoperable cruise. Remove stalk & check for broken wire/s, if OK it`s either faulty clutch switch (if manual) or faulty brake switch (likeliest problem).
Mick2.6
« Reply #6 on: 26 February 2011, 19:04:31 »
Where is the brake switch located. Is it under the dash next to the brake pedal?
« Reply #7 on: 26 February 2011, 19:09:48 »
Head in footwell, push brake pedal down and you`ll see the switch plunger actuate
Mick2.6
« Reply #8 on: 26 February 2011, 19:24:03 »
Thanks for the information, i will be sorting it out next week. I will be in touch if the problem is still unsolved. Thanks again :)
Page created in 0.009 seconds with 20 queries.
