Author Topic: Replacing CAR300 with Pioneer headunit  (Read 3780 times)
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« on: 26 February 2011, 16:32:41 »
I have trawled trough as many past posts as my head can handle and not found what i'm looking for so i'll ask a fresh Q.
I'm replacing the headunit for an aftermarket one.
Only single DIN, no steering controls to worry about, and I'm not fussed on it showing any radio info on the MID.
Soooo, with that in mind, what harness adaptor do i need to buy?
My stereo has ISO block connections...., will they just plug into the lower part of the 3 blocks? (the 2 smaller ones)
look kinda similar.
thanks
Hannah Judes Dad
    • the misses round the bend
Re: Replacing CAR300 with Pioneer headunit
« Reply #1 on: 26 February 2011, 19:19:17 »
From what I can remember you will need an ISO harness as the vauxhall wiring isn't the same as your headunit,I think you will need something like this
http://cgi.ebay.co.uk/PC2-04-4-Vauxhall-Omega-Senator-Signum-ISO-Lead-/160436669973?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item255ac54e15
I'm sure Dave DND will tell you if I'm wrong
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 27 February 2011, 14:14:14 »
If your Pioneer has a short set of leads with ISO connectors on, there should be bullets on the yellow and red wires - swap them over so yellow goes to red and red goes to yellow, and thats all you need to do.
Pc2-04-4 only needed if the ISO connectors are physically built into the radio
Radio & Decoding Technician
www.dndservices.co.uk
Hannah Judes Dad
« Reply #3 on: 27 February 2011, 17:01:02 »
Thanks Dave I knew that some part of the wiring needed changing but couldn't remember as it was that long since I've retro fitted a single din into a Vx. :y
o-meg-a
  • south wales
« Reply #4 on: 27 February 2011, 23:38:26 »
cheers for that  :y
