Author Topic: battery drain  (Read 2158 times)
omega2.2auto
  • stirling
battery drain
« on: 07 March 2011, 21:18:58 »
hi the battery on my omega keeps draining,not all the time though.went for a run yesterday done about 60 miles parked up jumped in this morning and batt was almost flat.nothing had been left on,last time was two weeks ago done the same  thing,sat all day at work and started no probs checked voltage charging at 14.12v any ideas.
Re: battery drain
« Reply #1 on: 07 March 2011, 21:26:30 »
Get your battery tested at a proper auto sparks.  ;)
omega2.2auto
  • stirling
Re: battery drain
« Reply #2 on: 07 March 2011, 21:52:35 »
will do that tomoz better than guessing
Re: battery drain
« Reply #3 on: 07 March 2011, 21:57:37 »
Have a good long read of this .... at least twice .. then follow Kevin's instructions.. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
Also, check terminals for any sign of heating as that could be a loose connection / corrosion which will stop any power getting to the battery even if the voltage is correct... remember voltage = "electrical pressure" .. not "flow" which is current .. :) .. you can have high pressure with no flow .. think thumb over the end of a hose pipe .. :)
Re: battery drain
« Reply #4 on: 07 March 2011, 22:09:51 »
...... you can have high pressure with no flow .. think thumb over the end of a hose pipe .. :)
or as an old Chief Tiff compared it ....... you can have a p*** without a sh** but you can't have a s**t without a p***  ::) ::) ::) ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: battery drain
« Reply #5 on: 07 March 2011, 23:11:44 »
Are ypu having intermitant central locking problems, ie having to lock it twice because it unlocks itself on tne first atempt?.
markrl
  • London
Re: battery drain
« Reply #6 on: 08 March 2011, 19:29:34 »
Don't tell me your another Fisgard old boy  :o
Re: battery drain
« Reply #7 on: 08 March 2011, 19:42:02 »
Lane Div 793 entry!  ::)  ::)  ::)  ::)
http://www.fisgardassociation.org/photos/class/793_class/fisgard_793_lane_new_entry_79.htm
Top row 3rd from left  ;)  ;)  ;)  ;)
