Author Topic: 2013 to 2015 upgrade.  (Read 10736 times)
Re: 2013 to 2015 upgrade.
« Reply #45 on: 10 March 2011, 18:47:07 »
But Omega glovebox has no use, so may as well do it the easy way ;)
« Reply #46 on: 10 March 2011, 19:50:19 »
These are the plugs...?
    • 530D M Sport, 330i Coupe
« Reply #47 on: 10 March 2011, 19:52:23 »
Grey CID/GID/Later MID connector for tm, might have to move some of the pins about.
Yep, tend to remove any of the unused pins and tails to keep the loom thickness down.
Have used the Blue shroud off the climate panel by carefuly triming one of the keys, allowed the clamp to lock down at least.
« Reply #48 on: 10 March 2011, 20:00:59 »
One on left is missing its latch...
« Reply #49 on: 10 March 2011, 20:03:49 »
Yeah, was missing on previous cars CID plug too. Stayed in no problem on that.  :-/
« Reply #50 on: 10 March 2011, 20:07:47 »
Blue ISO block can be binned.
Pop the two grey connectors in the post to me and i'll return anything that isn't used with the loom.
« Reply #51 on: 10 March 2011, 20:09:27 »
Keep the blue block, always handy, esp as it has latches on still ;)
« Reply #52 on: 10 March 2011, 20:31:57 »
Pm sent Andy.  :y
I only took the blue block as a referance for the hramen garden wiring, I need to replicate it.
In case it's relevant, ultimately intend to fit
 traffic master, I have the bits for that.
Harmen garden iPod emulator.
Telematics and boss amp to first aid boot cupboard.
Ac cooled glove box. (yeah right  ;D)
iPhone mounted near CID currently inter fears with CID. (not relevant here)
« Reply #53 on: 10 March 2011, 20:40:00 »
Pm sent Andy.  :y
Well will be making the loom based on a Trafficmaster loom so will leave the trafficmaster connector on so you can just plug in the box when ready (nb. if you have another phone kit fitted and don't have the trafficmaster box plugged in you will have to loop the mute line across).
So if you are sending me both grey plugs do you want me to make two looms? One full length to boot/first aid compartment and one short length for glovebox?
« Reply #54 on: 10 March 2011, 21:11:22 »
Pm sent Andy.  :y
Yes please, is my traffic master loom of use in that case?
« Reply #55 on: 10 March 2011, 21:26:10 »
Pm sent Andy.  :y
Trafficmaster loom always useful to TB or I!
Pages: 1 2 3 [4]  All   Go Up
