Author Topic: Phillips carin sat nav pre facelift  (Read 4750 times)
robg1984
  • immigham n.e.lincs
« on: 10 March 2011, 21:16:16 »
  Hi im going to be fitting the sat nav unit into my 98 elite in the next week or so and ive read the how to and it mentions cutting into wires as ive not got the clip :'( anyone know which wires it is ti cut into and maybe have a pic to make it easier :y
I_want_an_Omega
Re: Phillips carin sat nav pre facelift
« Reply #1 on: 11 March 2011, 10:14:52 »
Hi,
On a -98 Elite it shouls plug straight in - you wont need to cut any wires at all.
What do you mean by "Clip"?
robg1984
« Reply #2 on: 11 March 2011, 11:24:48 »
on the guide theres a plu/clip that the main loom off the wiring goes into behind the passenger side kick panel i dont appear to have it! :-/
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 11 March 2011, 11:45:54 »
it should be there, tucked up in the loom. was there on my mv6 when i fitted satnav.
robg1984
« Reply #4 on: 11 March 2011, 12:29:37 »
ill have a good look later when ive finished putting my gearbox in thanks :y
I_want_an_Omega
« Reply #5 on: 11 March 2011, 12:29:55 »
yes, it will be tucked away under the pass side A piller trim cover. It might be tucked behind the main look or taped to it. I've done two now and they were both there.
The thing to note is that if the sat nav isn't fitted that the (unused) connector needs to be secure to stop it hitting the trim panel and making a noise, it's pretty cramped in there so hene the need to tidy it up.
HTH - Rob
« Reply #6 on: 11 March 2011, 12:31:54 »
The prewiring to plug the Satnav loom in to is only on MY98.5 and MY99 cars. Early 1998 cars (built in 1997) will not have this.
robg1984
« Reply #7 on: 11 March 2011, 12:32:22 »
thanks lincs robert ive only had a quick look ill have a good later i thought it was goin to be noticable but i should have realised it would be tucked away after all it is an omega ::)
robg1984
« Reply #8 on: 11 March 2011, 12:34:58 »
its a 98 r reg think it was registered feb 98 so i may be out of look on that score then :'(
robg1984
« Reply #9 on: 11 March 2011, 12:38:04 »
also how do you find out if its a my98.5 etc car?
I_want_an_Omega
« Reply #10 on: 11 March 2011, 12:39:55 »
I think you will be ok as the 2.5 Elite was only introduced in the '98 Model Year (MY). One of the ones I've done before was on an R reg MV6 - which was a '98 MY so you should be ok.
Even if you arent then I have a length of loom hacked from another car, so it is possible to splice one in - if you know what you are doing that is!  :y
« Reply #11 on: 11 March 2011, 12:40:08 »
The fact you cant find the satnav plug ;)
I_want_an_Omega
« Reply #12 on: 11 March 2011, 12:41:16 »
Take the reg and chassis numbers to your local Vx dealer and ask the parts guy nicely. He should be able to look it up easily enough.
« Reply #13 on: 11 March 2011, 12:41:23 »
I think my MV6 was registered in Feb 98, its a MY98, but built in 1997, and didn't have the plug (does now, though I've long since binned the CARiN I fitted)
« Reply #14 on: 11 March 2011, 12:42:12 »
PM me the reg...
Page created in 0.186 seconds with 20 queries.
