Author Topic: Day time running Lights  (Read 12488 times)
Re: Day time running Lights
« Reply #15 on: 11 March 2011, 16:47:17 »
Issue closed:
http://www.omegaowners.com/forum/YaBB.pl?num=1299860937
............ bet it's not!  ;D ;D ;D ;D ;D
I_want_an_Omega
« Reply #16 on: 11 March 2011, 16:50:07 »
Don't care, so there. It's closed for me anyway!
« Reply #17 on: 11 March 2011, 16:52:51 »
Neither do I Rob ......... I was joking  ::) ::) ::) ::)
I_want_an_Omega
« Reply #18 on: 11 March 2011, 16:57:16 »
I know that  ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #19 on: 11 March 2011, 17:30:59 »
Handbags at dawn ? . . . . . . . .
 :P
Radio & Decoding Technician
www.dndservices.co.uk
youth
  • just outside boston
« Reply #20 on: 14 March 2011, 01:02:32 »
if you want them running why not just install a relay to the ignition live and run it to these led lamps wouldnt that just be so much simpler??? :P :P :P
youth
« Reply #21 on: 14 March 2011, 01:03:59 »
and by that i mean aftermarket relay the wiring to do this is rather simple and you can even buy the relays all fully wired up too :D :D :D :D :D :D :D
Kaycee
  • Doncaster
« Reply #22 on: 14 March 2011, 22:53:50 »
Thanks for all replies and comments but to clarify the sidelights Danny These are the four leds in a cluster and even in daylight are quite bright (not like me i might add)  but was  in the car when i bought it. I just wondered if these could be fed by an ign controlled  circuit and a diode to stop power going back up to switch when light circuit was off but what would happen when the power came from the switch. And yes i do switch on the lights in the dayime but the downside is the dash goes into night time mode if its not feasable then no i wont do it. Also most of you are right the fronts of the audis and mercs look like xmas rope lights very garish if that is the only option then i wont be having it. In the words of the old TV program " I only arsked"
and i do believe they are too bright I've noticed the insignias use the side light circuit and lighting is more subtle and finaly i think it is a good idea to have lighting during daytime as i am not in my car all the time i too am a pedestrian now and then.
Thanks once again
Robert
There is a tide in the affairs of man if taken at the flood will lead on to greater things
