Author Topic: Alternators  (Read 1870 times)
JLee
Alternators
« on: 15 March 2011, 07:36:16 »
hie guys just a quick one.... what are the implications of fitting a higher amp rated alternator? i mean like fitting a 120 amp alternator marked for a 2.5 v6 on a 2.2 CD which originally had a 70 amp unit
thanks in advance
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Alternators
« Reply #1 on: 15 March 2011, 09:40:41 »
Not a conversion I am familiar with, but Physical shape and size and connections are the only things I would want to check.
I do not see that the increased output would cause any concern.
Radio & Decoding Technician
www.dndservices.co.uk
JLee
Re: Alternators
« Reply #2 on: 15 March 2011, 18:23:06 »
thanks Dave
im thinkin of upgrading the alternator reason being if i have the rear demister on as well as the headlights coupled with the heated seats my battery light on the dash comes on but very faintly(Only noticed it by chance). on second thoughts should i replace the battery instead?
Re: Alternators
« Reply #3 on: 15 March 2011, 18:27:10 »
thanks Dave
The fact you light comes on under high load suggests you have problems with your existing alternator, the standard alternator should be capable of keeping up. I can't see you should have problems by putting a bigger alternator on though.
tidla
  • solihull
Re: Alternators
« Reply #4 on: 15 March 2011, 18:40:27 »
might be worth going throu the electrical checks as in the maintenance guide to find the real fault.
Re: Alternators
« Reply #5 on: 15 March 2011, 20:05:44 »
thanks Dave
Voltage regulator playing up. See guide for replacing
