Author Topic: radio controls on steeringwheel.  (Read 4909 times)
big mel
  • Oldham Lancs
  • ex trucker' GB. USA. CONTINENT& GB
    • Omega 2ltr gls 2000frpp
    • big melL
« on: 11 March 2011, 17:42:22 »
the radio controls on my mig have never worked since i bought it. it has a trafic master button & when i press it it mutes the radio. the radio &cassete is a blauput. i think the last owner must have had a different radio in. any ideas how to get the controls on the s/wheel working would be welcome. thanks in advance. big mel.
THE TRUCKERS MOTTO. keep the shiny side up & the greasy side down. the bugs off your glass &  the bears off your ass.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: radio controls on steeringwheel.
« Reply #1 on: 11 March 2011, 17:45:34 »
Exactly what model stereo do you have?
Is it an original Vx one?
Has any of the wiring been altered ?
Radio & Decoding Technician
www.dndservices.co.uk
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 12 March 2011, 08:06:48 »
remove radio (whatever you have in )  if it is an aftermarket i bet you only have one or two of the three plugs connected, if it is a standard h/u check the plug connections at the rear that they are seated properly  :y
big mel
  • Oldham Lancs
    • big melL
« Reply #3 on: 12 March 2011, 12:19:37 »
the radio is a double din v/hall standard fit. I can't remove it as I haven't got the tool that does the job. regards Mel.s
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 12 March 2011, 14:45:27 »
You will need to remove the stereo to check the wiring behind it
fiend61
  • york
  • each to their own
« Reply #5 on: 12 March 2011, 18:24:44 »
they are a couple of quid on fleabay and a bit dearer in halfrauds  :y
big mel
  • Oldham Lancs
    • big melL
« Reply #6 on: 13 March 2011, 16:16:45 »
Thanks for the info. will get the tool & have look behind the set. Thanks to Dave as well. Mel.
« Reply #7 on: 13 March 2011, 18:59:03 »
What radio is it, and does the info come up on the display?
big mel
  • Oldham Lancs
    • big melL
« Reply #8 on: 14 March 2011, 17:33:47 »
the radio/cassette is a blaupuct 2003 I think the last owner must have had trafficmaster because there is a button with t/m on it & when I press it' it mutes the radio I am going to halfords to buy the tool to removes the set this w/end & have a look behind it. regardes. Mel.
« Reply #9 on: 14 March 2011, 18:32:29 »
Never heard of that one.  Possibly cannot accept remote control, thus not working.
fiend61
  • york
  • each to their own
« Reply #10 on: 14 March 2011, 20:15:39 »
yup quite correct i think they were fitted to audi ???, you will need another interface lead that is compatable with the vauxhall steering wheel controls
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 14 March 2011, 21:08:18 »
CAR 2003 was a base model stereo fitted to Astra and Corsa
Not sure it was steering compatable ?
    • 530D M Sport, 330i Coupe
« Reply #12 on: 14 March 2011, 21:11:30 »
CAR300?
EDIT: Ah sorry, just googled it. Yep base model Corsa one that methinks!
« Last Edit: 14 March 2011, 21:12:45 by VXL_V6 »
big mel
  • Oldham Lancs
    • big melL
« Reply #13 on: 15 March 2011, 18:08:20 »
on the cassette it says blaupukt car 2003 it does'nt look like any of the sets pictured in the audio manual I have aug 1999. I did'nt know the Astra had the same fitting. I had a 1999 Astra & it did'nt look the same as the omega.s   thanks all u guys for all ur replies. cheers. Mel.
russ0205
  • northants
    • mondeo
« Reply #14 on: 15 March 2011, 21:02:19 »
Had a blaupunkt 2003 fitted in my combo van as standard don't think it can have steering wheel controls,
 :-[ :-[ :-[ :-[ :-[ :y
