Author Topic: played cds made on my computer  (Read 9688 times)
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: played cds made on my computer
« Reply #15 on: 26 November 2010, 13:31:39 »
Using CDR's in a standard head unit or changer will kill the laser very quickly. Only play original cd's or lose the cd player altogether, choice is yours ;) :y
why does that happen    i dont play copies in the car luckily
Put very simply  ... a "purchased" CD is "stamped" from a sheet of foil... and the working surface (the rear of the "label") is a mixture of highs and lows... with an actual physical difference existing... albeit very small ......
A "burned" CD (home made) the "foil" has a dye within the surface, when "burned" the dye is heated to change colour and gives the impression to the laser that the surface is at differing heights, so fooling it into giving the same output as the real highs and lows of the stamped disc.
The problem is .. the laser "knows" it needs to change the focus to get the high and low in focus every time .. but the "dyed" disc is all at the same distance .. so the focus mechanism of the laser is working overtime to achieve very little ... it thus wears out much faster....
Perhaps not totally accurate but gives the basic idea hopefuly
Daft question, but surely the laser focus moves the same amount, whether genuine hi/lo's, or fake dyed ones.
Therefore, although it ""achieves very little", I can't see why there would be any difference in the amount of movement & thus wear-out time?
Or am I missing something?
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #16 on: 26 November 2010, 13:56:20 »
its not the distance the laser travels that causes the problems, its the physical size of the pits and troughs of the data it is looking at on the cd. Audio data is a much larger physical format, when compared to the tiny computer data being written to by a home computer recorded disc. Its the laser struggling to focus on the smaller data that causes premature wear. Think about it, if you have to keep squinting to see something very small, sooner or later your eyesight will be knackered - same principle.
CDR`s and recordable media should not be used on ANY Omega stereo, and MP3 is not a format that any of them support anyway.
And I can confirm that any MP3 stereo will be fully compatable with recordable media, CDR / CDRW - obviosly there will be some performance issues depending on how the media is recorded
Radio & Decoding Technician
www.dndservices.co.uk
Lampynoiseboy
  • SE Essex
« Reply #17 on: 26 November 2010, 15:23:32 »
Ah, makes sense now..... funny thing was I actually knew that, just forgot that I did
Thank god it's Friday  :-[
osealy
  • dublin
« Reply #18 on: 27 November 2010, 20:45:57 »
I have been using cdr's for 60k + mls in two factory changers preface & miniface, no probs.
Lampynoiseboy
  • SE Essex
« Reply #19 on: 28 November 2010, 00:58:20 »
H/U changers, or remote?
« Reply #21 on: 28 November 2010, 09:30:52 »
The CDC2 (6 disk unit fitted to prefacelifts) is more resilient. The later CDC3 has fitted to *ALL* facelift cars with cd changers really are prone to laser focusing failure.
Road Hog Mad
  • Cheshire
« Reply #22 on: 20 March 2011, 19:23:01 »
Why does it make a difference at what speed you write it at? If it can burn a DVD for example at 16X why burn it a x2?
  • Auckland
    • Mazda MPV
« Reply #23 on: 20 March 2011, 21:12:49 »
The recording laser burns the pits in the CD-R. The laser switches on and off very quickly but it isn't instant so the beginning and end of each pit tends to smear.
If you double the rotational speed you double the length of the smudge at the end of each pit.
« Reply #24 on: 20 March 2011, 21:37:03 »
In laymans terms, you get a more accurate and consistent burn at slower speeds.
Its always best to burn anything at the slowest speed supported by the recorder/media combo, and always use top quality media, ie Verbatim or TY.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #25 on: 21 March 2011, 09:06:53 »
