Author Topic: Problems starting 3.2 manual  (Read 2297 times)
Arrolman
  • Renfrew,Scotland
« on: 22 March 2011, 12:11:43 »
Hi,
Having some serious problems getting the car to start. New battery fitted, won't start. Will start when bump started on hill no problem but starter doesnt seem to fire? On a hill rolling backwards slowly and ignition turned on, car will attempt to creep forward but won't start? Im guessing starter is knackered but would like opinions first. Pedal trick brought up following codes:
P0120 Throttle/PedalPosition Incorrect Ratio
P0120 Throttle/pedalPosition sensor/switch "A" circuit high input
P0120 Throttle/pedalPosition sensor/switch "A" circuit low input
P0120 Throttle/pedalPosition sensor/switch "A" circuit range/performanceProblem
P0220 Throttle/pedalPosition sensor/switch "B" circuit high input
P0220 Throttle/pedalPosition sensor/switch "B" circuit low input
P0220 Throttle/pedalPosition sensor/switch "B" circuit range/performanceProblem
Cheers,
Iain
« Last Edit: 22 March 2011, 12:12:22 by Arrolman »
Looking to win the lottery..........
Arrolman
  • Renfrew,Scotland
Re: Problems starting 3.2 manual
« Reply #1 on: 22 March 2011, 14:33:59 »
Now sorted :y, seized starter, lump hammer soon cured it, anyone have any idea on the codes though?
Cheers,
Iain
